| | | Forums66 Topics128,015 Posts1,055,335 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 314 Shop Shark | | Shop Shark Joined: May 2005 Posts: 314 | After having put the alternator from the donor van in the '48 last weekend, I found that it wasn't charging... then the stovebolt page went down and I couldn't ask for help... I searched around the web and found out that the "Dummy" light wire isn't just for "Dummies". It also supplies the power to excite the alternator into action. I installed a dummy light and got the alternator working.
I also started fabrication on the new dump body. The original is beyond salvage. The new one is being modeled after the original, with some minor dimensional changes. When it is done it will look nearly identical to the original. | | | | | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Attended 2-shows this weekend. Saturday, I took the 46 to Trapper-Days in Ft. Lupton, CO. Ate some great BBQ.
On Sunday, we had a local show, in the parking lot of a boot/western wear store. I took both the 46, and the 52.
No tropies, but I did walk away with the grand door prize. It's a garage in a box...
It has a pair of chocks, jack stands, a hydraulic floor jack, and a creeper.
Beyond that, just had alot of fun. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Inky, the "dummy" light also tells you instantly if you've thrown a belt. You don't have to wait to notice the engine has overheated. | | | | | Joined: May 2005 Posts: 314 Shop Shark | | Shop Shark Joined: May 2005 Posts: 314 | Yeah, Cletis, I figured I might as well go ahead and put it in. It's a $2.99 insurance policy.
Hated the thought of drilling the hole in the dash though.
Also, I read somewhere that the exciter wire needed to have at least 35 ohms of resistance to keep from frying the regulator. The bulb provides the resistance. | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | I wrenched on the '67 this weekend.. finally got the hang of putting a tire on a rim by hand.. goes pretty quick once you figure out the tricks!
Said goodbye to Ziggy (50 1/2 ton) on Sunday as his new owner (a 17 year old kid who wanted it to pull his home built teardrop trailer!) and as soon as the Okie from Miskokie picks up the '50 2 ton, i'll have some space cleared up to start putting the new box on the '46 big bolt and hopefully start building my new 40x60 garage/pole building.
| | | | | Joined: Sep 2001 Posts: 466 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 466 | Went on a cruise, two 55.1 Chevy Pickups. Mine is the "before" examlpe and the other one is the "after" example. Also a '51 Merc and a '55 Buick. Did about 120 miles total, went for the BEST BURGER IN ALASKA at the Monderosa.
Buddy | | | | | Joined: Aug 2004 Posts: 476 Moderator | | Moderator Joined: Aug 2004 Posts: 476 | Got the cement project finished up. One more domino down in the garage expansion plan. Also finished a drainage project. Both big jobs and glad to have them finally done. Waiting on a new grandbaby any minute too.
Don't lose your head to save a minute, You need your head, your brains are in it. Burma-Shave (1947)
