| | | Forums66 Topics128,201 Posts1,057,281 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 355 Member | | Member Joined: Feb 2005 Posts: 355 | OK guys, I've been looking for parts for my '59 and I need some super-basic help. I've got a catalog that describes carbs the following ways:
1 BC 2 BC 1 BBL 2 BBL 4 BBL
Can somebody un-abbreviate these for me? Thanks for information. I'm learning from you all every day. | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | Go to NAPA auto parts ,they can help.They have the parts
dan-pa
| | | | | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | I'll guessing that BC means Barrel Carb. I know for fact that BBL is widely used as short for Barrel.
Mike Barnes 1950 GMC 1-ton pickup
| | | | | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | Note the Rochester B is manual choke, Rochester BC is autochoke. To avoid confusion I'd avoid using BC for other meanings when talking old Chevrolet. You should contact carbking if you want top quality guearanteed to work carburetors with the support of Jon Hardgrove who I believe is the worlds top expert on vintage carbs. His inventory and selection will blow your mind. Contact the expert and get advise you can trust: [email protected]
| | | | | Joined: Feb 2005 Posts: 355 Member | | Member Joined: Feb 2005 Posts: 355 | Great. Thanks guys. I was familiar with the BBL, but I'd never seen the BC before. The Rochester explains it.
Thanks again! | | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Kimberly,
I would also advise on contacting carbking. He has not been around much since you have been on, but he knows his stuff! | | | | | Joined: Feb 2002 Posts: 2,896 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,896 | carbking Member Stovebolter # 2929
profile with email addy:
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_profile;u=00002929 | | |
