7 members (Bill Hanlon, Oswald, elhippie64, moparguy, 1955 1 Series, Southerntruck, 1 invisible),
99
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,154 Posts1,056,834 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | if you can't get a new tank this might help for some i just found it this morning while looking for something completely different. here goes http://www.ripper1.com/tech/rust.htm gooday jim
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | That is an interesting twist on rust removal for a gas tank. Thanks
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | You can also use lye. Grocery stores here sell it for about $6 a can.
Fred 52 3600 69 C-10
| | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | I like the one that suggests using a piece of rebar and a 10 amp battery charger to electroplate the rebar with the rust.
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | pouring salt on the tail of... I thought some would enjoy this ...insite. let's spark that baby
''Pour salt in through the funnel until the current climbs to 10 amps, and wait approximately 2 minutes'' until . . . . . . .
| | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Er...
Wouldn't that re-bar thing just arc?
Or is this the same rust-removal process for sheet metal that they were discussing in the body shop a few weeks ago with the electrode and the electrolite solution? | | | | | Joined: Jun 2005 Posts: 221 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 221 | you have to insulate the steel rod do it doesnt short against the tank a piece of rubber hose on the spots where it touches the thank will work. | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | I'm gunna try it with a rusty bucket.. wonder how much salt you need to get it up to 10 amps?
| | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Originally posted by Fumblin46: I'm gunna try it with a rusty bucket.. wonder how much salt you need to get it up to 10 amps? Let us know how it works out, Fumblin! | | |
