Brrrr
place holder
6 members (Charles in CA, Gdads51, klhansen, 2-Ton, joe apple, Forty9), 163 guests, and 1 robot.
Topics128,274
Posts1,058,428
Members48,489
if you can't get a new tank this might help for some
i just found it this morning while looking for something completely different.
here goes
http://www.ripper1.com/tech/rust.htm
gooday
jim
Jim & Caroline
That is an interesting twist on rust removal for a gas tank. Thanks
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
You can also use lye. Grocery stores here sell it for about $6 a can.
Fred
52 3600
69 C-10
I like the one that suggests using a piece of rebar and a 10 amp battery charger to electroplate the rebar with the rust.
pouring salt on the tail of...
I thought some would enjoy this ...insite. let's spark that baby
''Pour salt in through the funnel until the current climbs to 10 amps, and wait approximately 2 minutes'' until . . . . . . .
Jim & Caroline
Er...
Wouldn't that re-bar thing just arc?
Or is this the same rust-removal process for sheet metal that they were discussing in the body shop a few weeks ago with the electrode and the electrolite solution?
V
V Offline
you have to insulate the steel rod do it doesnt short against the tank a piece of rubber hose on the spots where it touches the thank will work.
I'm gunna try it with a rusty bucket.. wonder how much salt you need to get it up to 10 amps?
Quote
Let us know how it works out, Fumblin!
