| | | Forums66 Topics128,032 Posts1,055,438 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2003 Posts: 22 Junior Member | | Junior Member Joined: May 2003 Posts: 22 | My '59 doesn't have the VIN tags on it, so is my only recourse contacting BMV and getting new tags.
'50, '59, 1/2T, GMC
| | | | | Joined: Jun 2001 Posts: 5 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2001 Posts: 5 | if its achevy the vin is also on the frame, drivers side in engine comp by park brake pivot | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | It all depends on the laws in your state. If you need the vin plate to get the vehicle registered, yes. If they don't required a vin inspection, you should be okay. Usually the DMV or highway patrol handles this.
Fred 52 3600 69 C-10
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Originally posted by tater: My '59 doesn't have the VIN tags on it, so is my only recourse contacting BMV and getting new tags. But do you have the title? I've never needed to show any tags on any of the truck I've got to get it licensed, heck, I've never even confirmed the titles match the tags on most of them. If you have the title, just go down and register it. Scott | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Then, if the number on the frame doesn't match the title, you can get it corrected. Relatively easy, if you know a law enforcement officer to sign off on it hassle-free. | | |
