7 members (moparguy, Chris_Welch, Gdads51, homer52, texas46, 2 invisible), 139 guests, and 4 robots.
Topics128,267
Posts1,058,386
Members48,485
#187978 08/18/2005 6:13 PM
Went looking for radial tires for my 49 and found Bridgestone 215/85/16 selling for $180 each plus mounting, valves and balancing and of course 15% sales tax! All Canadian dollars. That will equate to around $1000 by the time I am back on the road. I think for a truck that runs about 2000 miles per year it is a bit pricey. The tires are also 10 ply and I am wondering how stiff a ride that would give me especially when I carry very little or nothing in the box. Anyone have any ideas on less expensive rubber and something with fewer plys.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#187979 08/18/2005 6:33 PM
look for some Yokohama LT tires - my 700R15LT's were $712 for 4 all up - they're 10 ply and a little harsh, but not unbearably if you don't use the highest recommended pressure - got a Big O in the area?
#187980 08/18/2005 7:36 PM
Thanks Bill there is one in town. They quoted me on the Bridgestones. Being 16" they could be pricier - ya think?
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#187981 08/18/2005 8:14 PM
big o can special order kumho 215/85-16's for about $85/tire u.s. they are slim, high, black walls that ride great, corner well and don't cost a fortune. no white walls though in that size.
Overland Blue, 1953 GMC 1/2T, 100-22, 228/1bbl, 4sp/4.10 6v, shortbed/fender side/5-window.
#187982 08/18/2005 8:40 PM
Canadian Tire has Roughrider A/T tires on sale in the size you want for $100.49 each. Price includes mounting and valve. They are D rated (10 ply are E rated).
www.canadiantire.ca
Gord
1954 1/2 ton 235 4 speed
#187983 08/19/2005 5:17 PM
I got a set of those Kumho's from www.tirerack.com
They were in stock and then on my door in about 2 days. So far, they seem to be pretty good. Worth a look anyway.
-J
'52 3800 Panel
School bus conversion... Glass all around. (check the gallery!)
outside of a dog, a book is a man's best freind.
inside of a dog it's too dark to read.
-Groucho Marx
#187984 08/19/2005 7:22 PM
I went to Costco Wholesale ~$100 each + mounting and balancing, out the door with 5 tires for under $600. These are BF Goodrich Radial Commercial Truck tires, load range D, 8-pli, they are tall, skinny and the ride is unbeatable.
[img]http://www.kinemation.com/Trucks/gmc100/frontenddone.jpg[/img]
These are LT215-85R16's running at 35 psi - they are rated to 60 psi, but too bouncy at that pressure. Costco is typically about 20 - 30 percent cheaper than the same tires at other stores.
Life's short - don't waste it.
