| | | Forums66 Topics128,198 Posts1,057,272 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | OK I have two 55gal drums in the back of my Stovebolt. How the HECK do I remove the lids so that I can use them as burn barrels? Surely some of you do-it-yourselfers have had to deal with this situation before.
delete my account and pictures
| | | | | Joined: Oct 2001 Posts: 194 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 194 | If they have crimped on lids as most do, take a big chisel and a big hammer and just chisel your way around the inside of the crimp.
Very easy to do and much safer than using a torch. Make sure they are empty and rinsed clean beofre you start. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | My "barrel guy" has a huge can opener, just peels the lids right off if you want. Air chisel will also work well. Brian | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Sawsall with ear plugs, Scott | | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | I thought about the hammer / chisel but didn't know if it would work. The air chisel is a good idea. I've needed one of those for a long time anyway.
Where does one find a "barrel guy"? lol....
| | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | 48bigtrucks: You mean a scroll saw? But I need to have a lid to put back on to keep the water out. And hell yes, I will wear ear plugs. I wear them just about all the time anyway. I've abused my ears in the past and I'm paying the price.
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Tab, I have removed many tops with the hammer/chisel combo. With a sharp chisel and heavy hammer it is amazingly fast, and sort of fun too. Wear a good glove on the hand holding the chisel. When done properly, it gives a pretty burr free edge. When the top drops into the barrel, leave it there...the bottom won't rust out as quickly. Be sure to slice air vents around the bottom to aid in combustion.
Stuart. | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Im make sure they are clean,and use the old smoke wrench.Works great. | | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | atomarc: Thanks! Looks like the hammer and chisel it is.
dale937: What's a "smoke wrench"?
| | | | | Joined: Jan 2004 Posts: 255 Member | | Member Joined: Jan 2004 Posts: 255 | Do not use a torch on any barrel. I had a buddy that had one explode on him with what he thought was a clean dry barrel. Use a chisel and hammer and when you are done, lay it down on a 2x4 and hammer the burrs flat against the side. I make lids for my feed barrels out of plywood. I made a circle cutting jig for my router and I cut one circle the diameter of the inside of the barrel and another about an inch bigger in radius and just screw them together and use a screen door handle to lift them off. I have had some of these outside without paint for 10 years or more. Ralph | | | | | Joined: May 2005 Posts: 147 Shop Shark | | Shop Shark Joined: May 2005 Posts: 147 | I have used an air chisel tool, I did work at a place that had a big can opener.
Cool tool, made for opening drums, plasma cutter also works.
The ones I try to find now have removable lids, you can put the lid back on, keep the rain out.
Those are sweet, and it will last longer...
-RT1 | | | | | Joined: Dec 2002 Posts: 86 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2002 Posts: 86 | The tool you are looking for is called a drum deheader. They run about 65 bucks. You can order one online, newpig.com p/n DRM561
47.5 Loadmaster 5 window 48 Chevy 3600 69 GTO convertible | | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | Ray: Holy crap! You have a 69 GTO convertable? 69 was THE best year for the Goat.
I want to decrimp that lip so that I can remove the lid but I may not be able to do it with the tools that I have.
When I take my hammer and chisel to these things should I work around the side of the lid or set the barrel upright and chisel the top?
| | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | Oldtmy48: I JUST read a story on the net about a mechanic who was killed using a torch to cut the lid off of a 55gal drum. The cause of death; "blunt force trauma". darn thing blew up.
Some of those drums had some nasty chemicals inside. I got some marked "sorbitol".
| | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | oldtmy48: thanks for that lid making tip.
Ray: Thanks for the drum deheader tool tip. Since I only have two drums, buying another specialty tool is not what I want to do right now, but I will keep it in mind.
| | | | | Joined: Dec 2002 Posts: 86 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2002 Posts: 86 | Tab, Check your area For drum dealers. I pay $23 apiece for used openheads ( removeable tops ). As for the GTO your right i prefer the 69.
47.5 Loadmaster 5 window 48 Chevy 3600 69 GTO convertible | | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | OK, it wasn't fun but it's done. timcan
| | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | Ray: I got my drums for $3.00ea at a local scrapyard. I'm going back to get some more for rain barrels.
After 69 GTO's got uglier . They were still ok but nothing like the 69. The 69 Judge is my all time favorite car. I saw one driving down the road here in TexAss last year in a downpour. It looked like the guys daily driver. Oh, do I miss the 60's and early 70's.
