| | | Forums66 Topics128,051 Posts1,055,730 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 314 Shop Shark | | Shop Shark Joined: May 2005 Posts: 314 | On my '48 1.5 ton the heater hoses go through the heater core and then through the firewall again. Why do they go through twice? | | | | | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | Huh? Where would the water go if not back to the pump and radiator to be recirculated back to your heater again?
Mike Barnes 1950 GMC 1-ton pickup
| | | | | Joined: Feb 2000 Posts: 986 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 986 | With out seeing your truck my guess would be the one of the hoses goes to a control valve. But it is just a guess. Got any pictures?
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: May 2005 Posts: 314 Shop Shark | | Shop Shark Joined: May 2005 Posts: 314 | | | | | | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | The two on the left are what it should be using..Did you look under the dash, and see if there is a Still under there..You might have a mason jar full..Have no clue about the other hose..Have fun, Steve | | | | | Joined: May 2005 Posts: 314 Shop Shark | | Shop Shark Joined: May 2005 Posts: 314 | Steve, I thought the two on the LEFT under the Horn were the heater core. | | | | | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | You are right, guess I misunderstood what you were trying to do..Sorry | | | | | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | The hose under the horn is going to a heater controal valve and then into the heater. the hose on the left is the return hose to the radiator. This truck must have a deluxe fresh air heater as they were the one that used this type of valve. | | | | | Joined: Feb 2000 Posts: 986 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 986 | This is the same set up that I have. Some of the venders carry rebuild kits for the Control valve. If you look inside the cab and under the dash there should be a rod that goes from the control Valve to a knob at the bottom of the dash.
