0 members (), 52 guests, and 0 robots.
Topics128,050
Posts1,055,643
#187222 08/10/2005 1:20 PM
I
I Offline
On my '48 1.5 ton the heater hoses go through the heater core and then through the firewall again.
Why do they go through twice?
IRWIPI 2005 Peoples Choice
Inky,
"It's not that I haven't done IT... It's that I haven't done IT yet."
'48 1-1/2 ton Dump
'57 Chevy Panel
'59 Chevy 2 ton Dump
#187223 08/10/2005 1:31 PM
Huh? Where would the water go if not back to the pump and radiator to be recirculated back to your heater again?
Mike Barnes
1950 GMC 1-ton pickup
#187224 08/10/2005 1:43 PM
With out seeing your truck my guess would be the one of the hoses goes to a control valve. But it is just a guess. Got any pictures?
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
#187225 08/10/2005 3:22 PM
I
I Offline
Inky,
'48 1-1/2 ton Dump
'57 Chevy Panel
#187226 08/10/2005 3:31 PM
The two on the left are what it should be using..Did you look under the dash, and see if there is a Still under there..You might have a mason jar full..Have no clue about the other hose..Have fun, Steve
#187227 08/10/2005 3:58 PM
I
I Offline
Steve, I thought the two on the LEFT under the Horn were the heater core.
Inky,
'48 1-1/2 ton Dump
'57 Chevy Panel
#187228 08/10/2005 4:36 PM
You are right, guess I misunderstood what you were trying to do..Sorry
#187229 08/10/2005 8:56 PM
2 Offline
The hose under the horn is going to a heater controal valve and then into the heater. the hose on the left is the return hose to the radiator. This truck must have a deluxe fresh air heater as they were the one that used this type of valve.
#187230 08/11/2005 3:10 PM
This is the same set up that I have. Some of the venders carry rebuild kits for the Control valve.
If you look inside the cab and under the dash there should be a rod that goes from the control Valve to a knob at the bottom of the dash.
Brian Moore
