| | | Forums66 Topics128,014 Posts1,055,330 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 95 Member | | Member Joined: Feb 2005 Posts: 95 | ok so therse some paint on the plastic cover for the guages.. anybody know a good way to get this off.. tricks of the trade. good ideas.. anything | | | | | Joined: Sep 2004 Posts: 168 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 168 | Baby oil, mayo, goof off, WD-40...
jay
Your lack of preparation is not my emergency
| | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | How about a Dremel with a buffer tool on the end? | | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | megular makes a plastic cleaner and polish. | | | | | Joined: Feb 2000 Posts: 985 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 985 | Maybe check with the local body shop or paint supply store and see what they have?
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Jun 2002 Posts: 150 'Bolter | | 'Bolter Joined: Jun 2002 Posts: 150 | In my experience, dremels turn too fast to control the heat buildup on plastic. Meguiars (sp?) makes a fine plastic cleaner/polish. That, an old school (clean) diaper and elbow grease make for a good looking lense. Mike | | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | use a razor blade then if you scratch the glass slightly, polish it with a buffer and compound.
delete my account and pictures
| | | | | Joined: Jun 2004 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 100 | Check with a sign shop and ask if they have "Lacqueryl"... I may have messed up the spelling. I used to work for a sign guy and this is what we used on plastic or lexan sign panels to remove paint without ruining the face. I'll check into it on Monday.
Andy
A man is like an old truck... He will rust out before he wears out...
