4 members (Rick Brown, Bill Hanlon, 2-Ton, 5 Window 9434), 198 guests, and 1 robot.
Topics128,108
Posts1,056,238
Members48,437
#186973 08/05/2005 10:48 PM
Hey Guys, just starting to paint the original leaf springs and front axel on my '48 (w/POR 15) and before I assemble them back together , I was reading an article in Chevy Duty about removing some of the leafs to lower my truck. Any body dun this? Thanx 4 ya help! Mike
#186974 08/06/2005 12:44 AM
I have. Took 3 leaves out of the front. It will bottom out on a medium sized bump, but once you get used to it, you know how fast to go over them. I'm gonna put a sway bar on to balance out the load a little more and see if that helps.
#186975 08/06/2005 1:31 AM
Hey Ship, wanted to lower mine a bit, which ones did you take out?..bottom, top, or middle, and did you put on some new u-bolts?..Thanks, Steve
#186976 08/06/2005 3:21 AM
I have driven/owned trucks where leaves have been removed and it is not a comfortable experience. You lose capacity but perhaps more importantly, you lose rigidity.
Alternatives include dropped axle, mono-leaf springs, and re-arched (de-arched) or custom springs.
dropped axle
custom springs ( their beliefs )
mono-leaf springs
#186977 08/06/2005 4:01 AM
Norse is right. It rides a little like a bowl of Jello. Hopping a sway bar will help. I plan on putting one on the back end too. If it does not help I will just go to monoleafs. I can't remember which leaves I took out. I still have them so tommorow I'll check it out and get back to ya. On the U bolts, I just threaded them down a little further and put on double nuts. I would just go back stock but it looks like a 4x4. I hate it. Don't mind the ride though. By the way, don't take leaves out of the rear to lower. Use blocks. The loss in rigidity in the back will cause driveline vibration.
#186978 08/06/2005 12:49 PM
Thanks..Don't want to lower the back, just the front..Already have a sway bar, and it's great..Appreciate ya, Steve
#186979 08/06/2005 2:49 PM
Thanx for the info guys! I 2 plan on putting a sway bar in the front and rear. I put one on the front of my '66 and it took all of the top heavy feel out of it so it auto work great on the '48. Thanx again!Mike
#186980 08/07/2005 2:42 AM
Here's an approach to lowering the front. I don't recommend this, but did find it interesting...
[img]http://www.oldsub.com/images/2005/08/hot_rod_arama/PIC00025.jpg[/img]
This is the entire truck...
[img]http://www.oldsub.com/images/2005/08/hot_rod_arama/PIC00021.jpg[/img]
#186981 08/07/2005 9:24 PM
Maybe in a parade ? not back and forth to work! smile
#186982 08/08/2005 8:01 PM
Apprentice
Apprentice
What about the rear end removing springs back there make it ride or handle different? If so what is a better way to lower it?
Jim
1940 Chev pickup Retro Rod
1957 Buick Century
1968 Mustang (Golden nugget)
2004 Trailblazer
Pix on Cardomain
#186983 08/11/2005 10:46 AM
I have removed 2 leafs from the rear(not the shortest one but the 2 after that)I had 8 leafs to begin with and now 6 lowered it and rode smoother.Now as far as loads I dont know because my truck was retired, she was just for looks ,cruzin around , no more hard work for her, and it was just fine. I pur 15 x 8 with 70 ser. tires and clearance was ok also. Hope this helps, Mike
