3 members (Hotrod Lincoln, Wally / Montana, Southerntruck), 72 guests, and 2 robots.
Topics128,060
Posts1,055,831
#185367 07/13/2005 4:25 AM
I :mad: :confused: need help im a die hard chevy man and want to updatemy 1942 pickup with a 327 300hp and 5speed manual tranny late model chevy and change the frount end to rack and pinon stering and disk without using a mustang 2 frount end any help??IDEAS ????HELP!!!!!!!!!!!!
ya I know a few rednecks.Thay all drive chevys to,
Proud member of the Old Dominion Stovebolt Society
AND A MARINE
trucks range from 1942 1/2 ton to 1965 fire engine
#185368 07/13/2005 6:02 AM
I don't think there is a good way to put rack and pinion on a straight axle. If that is what you are trying to do you have a tough challenge ahead.
The problem is unless you mount the rack on the axle you have a bump steer problem, but if you mount the rack on the axle you have increased the unsprung weight, plus you have a challenge connecting the steering column to the rack.
If you want IFS but object to using a Ford product, you might look at doing a front clip, or a Jag or Corvette system.
#185369 07/13/2005 12:01 PM
pacer IFS
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#185370 07/14/2005 12:37 AM
I bought a 1950 chevy axle from a guy how said it had holes in it for a rack and pinion. He said that it worked great but i never tried it out because my truck seemed to drive as good as it should already with a stock box.
I put disk brakes on my chevy using mustang two rotors and pistones. they had a chevy lug pattern on them so i could use chevy wheels. I bought a braket to bolt this on to the axle. I got the stuff from so-cal speed shop it all cost me less than $400
