0 members (), 160 guests, and 5 robots.
Topics128,149
Posts1,056,818
Members48,456
#185224 07/10/2005 9:46 AM
well i got everything together to redo the front brakes 49 chevy but the adjuster studs are froze in the pot metal cups iv sandblasted everything clean and soaked them in kroil i put a pipe wrench on and tryed turning them dont want to brake them is there any hope for getting them to loosen up help i was going to heat them up next
#185225 07/10/2005 11:05 AM
Junior Member
Junior Member
If these are the same adjusters as I have on my 50 1/2 ton, you'll have to use heat to free them initially. I used an oxy/aceyt. torch. It won't take much heat.
#185226 07/10/2005 4:45 PM
Socket Breaker
Socket Breaker
If all else fails, you can buy new ones, I think.... yeah cuz my dad got new ones for his '53 chevy .
good luck getting yers freed up, I had a stuck one on my '65 that I had to put in the vice with some liquid wrench, etc.. Finally got it to break loose.
-W
