1 members (RLB), 92 guests, and 2 robots.
Topics128,143
Posts1,056,494
Members48,442
i was lookin at this expandabel foam that u spray in.. do u think that if sprayed in small crevicies it might stop noise and such??
has anyone ever tried it??
The stuff will break down over time, plus it holds water
Ter Offline
Good idea, but I would worry about water, road salt, etc. seeping in and corroding the metal.Had a '36 ford that had some kind of "stuff" put in the door panels and it had settled on the bottom and the trapped water had rusted out the panels.
Ter
some of that spray foam is also corrosive to metal w/o the trapped water, and it really expands, so if you shoot too much in the wrong place it will distort any panel it pressures
eek
I've seen that stuff bow walls in houses - I would stay away from that stuff!! It'll do you more harm than good!!
.. there is some sort of spray deadner available, i've heard probably at any large parts house. it doesn't expane that much.
or
buy a sheet in dynamat..., the kits are way more expensive, go for the roll. boy the stuff ain't cheap but you don't necessarly have to cover the entire interior panel, roof, doors, back panels, under floor. cut w/ sissors, peel off the backing, stick it on. done!
Gooday
Jim
small wheel moves by fire and rod,
big wheel fires by the grace of god,
everytime that wheel turns round,
bound to cover just a little more ground.
thanks everyone for ur input.. i guess i didnt stumble upon somethign awesome.. darnit!
Stay away from spary foam! Nasty stuff, hard to get off hands, clothes, walls, floors, etc. etc.
Tempest
Tempest
"Find Your Inner Truck"
Silly Boys! - Trucks are for Girls!
1945 2-ton
1946 3/4-ton
1951 Chevy 2-Ton
Redliners Auto Club
What\'z It
Snow Cruisers
