2 members (Hush, delky),
141
0
Mod | | | Forums66 Topics128,126 Posts1,056,354 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 95 Member | | Member Joined: Feb 2005 Posts: 95 | i was lookin at this expandabel foam that u spray in.. do u think that if sprayed in small crevicies it might stop noise and such??
has anyone ever tried it?? | | | | | Joined: Jun 2003 Posts: 331 Member | | Member Joined: Jun 2003 Posts: 331 | The stuff will break down over time, plus it holds water | | | | | Joined: May 2002 Posts: 144 Shop Shark | | Shop Shark Joined: May 2002 Posts: 144 | Good idea, but I would worry about water, road salt, etc. seeping in and corroding the metal.Had a '36 ford that had some kind of "stuff" put in the door panels and it had settled on the bottom and the trapped water had rusted out the panels. Ter | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | some of that spray foam is also corrosive to metal w/o the trapped water, and it really expands, so if you shoot too much in the wrong place it will distort any panel it pressures
Bill | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I've seen that stuff bow walls in houses - I would stay away from that stuff!! It'll do you more harm than good!!
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Aug 2004 Posts: 90 Member | | Member Joined: Aug 2004 Posts: 90 | .. there is some sort of spray deadner available, i've heard probably at any large parts house. it doesn't expane that much. or buy a sheet in dynamat..., the kits are way more expensive, go for the roll. boy the stuff ain't cheap but you don't necessarly have to cover the entire interior panel, roof, doors, back panels, under floor. cut w/ sissors, peel off the backing, stick it on. done!
Gooday Jim
small wheel moves by fire and rod, big wheel fires by the grace of god, everytime that wheel turns round, bound to cover just a little more ground.
| | | | | Joined: Feb 2005 Posts: 95 Member | | Member Joined: Feb 2005 Posts: 95 | thanks everyone for ur input.. i guess i didnt stumble upon somethign awesome.. darnit! | | | | | Joined: Jun 2003 Posts: 92 Shop Shark | | Shop Shark Joined: Jun 2003 Posts: 92 | Stay away from spary foam! Nasty stuff, hard to get off hands, clothes, walls, floors, etc. etc.
Tempest | | |
