8 members (JW51, Woodcmiami, Gdads51, dt235sd, MickeyP, HandyAndy, k2handyman, 1 invisible),
58
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,699 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#18517 05/12/2004 2:31 PM | Joined: Jul 2002 Posts: 188 Member | | Member Joined: Jul 2002 Posts: 188 | 49 3600 has the stock lever action shocks. The manuel instructions for filling them with fluid say remove front cover and replace with one that has a fill plug(!?). I have wire brushed all 4 and cleaned with solvent. The front cover has NO fill plug. The only openeing I can find is toward the top back of the shock and it has a slotted head. This appears to be the relief valve comparing to the manuel. I'd like to keep the shocks, but can't figure out how to fill them. | | |
#18518 05/12/2004 3:23 PM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I've seen those covers with a fill plug, it's just a small pipe plug near the top. Just pull off the covers and drill and tap for small pipe thread. Would be a quick and easy solution. | | |
