1 members (NJC), 62 guests, and 1 robot.
Topics128,089
Posts1,056,004
Members48,430
is it difficult to remove and reinstal a tailgate??
the sides seem to be comin apart of i want to take it off and re weld them.. my dad thinks is a bad idea.. but i figured ti be good to find out from the pros... neither me or him realy know
V
V Offline
2 bolts on each side that hold the hinge to the bed you only need to take one side loose and you can lift the gate off.
oh by the way.. its a 1961 stepside ... if that makes a differnce
no difference - comes off as jimmy said, though don't be suprised if the bolts are rusted solid - you'll prolly find the rear posts are cracked at the rearmost cross sill near where the gate hinges - welding it up will help - dads always think their kids ideas are bad grin
hahaha.. alright tahtnks guys
ok new problem!!...
tried to turn bolts.. the thing thier conected to inside is just spining too.. now wat do i do?
ok i fixed it guys.. tahnks for all ur heelp.. yaa im ognna get soemthing done
Tab Offline
My welds broke too. Instead of weld them I put a 1/2" threaded rod through the upper part of the tailgate and bolted that sucker together. I didn't even have to remove the tailgate. It's been this way for many years with no problems.
delete my account and pictures
