0 members (),
96
Mod | | | Forums66 Topics128,093 Posts1,056,474 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 466 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 466 | This is simple, Maybe? I'm planning on building a shop. I know a lift will be a nice addition but how important is it? How much will it be used vs how often will it just be taking up floor space? This will be for ongoing project after project, retired guy playing a little every day.
What say you, please vote 1 to 10. 1=not needed use money for something else, 10=every shop needs one!
Buddy | | | | | Joined: Jun 2005 Posts: 153 Member | | Member Joined: Jun 2005 Posts: 153 | buddy in AK, i say 10. No more ramps! tony from CA
Overland Blue, 1953 GMC 1/2T, 100-22, 228/1bbl, 4sp/4.10 6v, shortbed/fender side/5-window.
| | | | | Joined: Feb 2004 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2004 Posts: 36 | Once you use it, you'll NEVER want to be without it again. 15 *ps* you can also put 1 'bolt on the lift, lift it all the way up, then slide another 'bolt underneath it... 2 for 1
artificial intelligence will never overcome natural stupidity
| | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | If you have the room, do it!
Since it's a new shop, make room for it!
10.
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass. Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
| | | | | Joined: Sep 2001 Posts: 466 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 466 | Hmmmm..... there seems to be a pattern forming here.
I did see an ad for the 4 poster with one car up and one car under, good idea.
Current plan is 36' square shop with one 16' wide door tall enough for a COE. | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | Hi, Buddy,
Door tall enough for a COE? I don't see one in your list so you must have plans! Do you have one spotted?
I'd say go for a lift if you can do it. It sure beats jack stands or a pit. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Dec 2003 Posts: 265 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 265 | My friend has one... sure wish I did. | | | | | Joined: Mar 2005 Posts: 158 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 158 | rdbates, why do you need a lift if your friend has one? Cold barley pops are cheaper than a lift; and it's always good to have help... | | | | | | Anonymous Unregistered | | Anonymous Unregistered | If you have the money and need to spend it. Go for it. I'm a 10 cause I wish I had one, but I dont think it is necessary for me,I'm not getting one. Good luck, have fun, enjoy yourself. Build the ultimate shop!  | | | | | Joined: May 2005 Posts: 147 Shop Shark | | Shop Shark Joined: May 2005 Posts: 147 | 10,10,10 Go for it, a guy up the street has one...sweet can park another car under it. I would love one.
-RT1 | | | | | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | I say build it into the budget for your shop. 10
For those of you that know about my Raffle, each year I have contacted a couple of the lift mfgs about donating a lift to our Tools for a Cure Raffle, no such luck YET!!!!! Boy would that sell some tickets!
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I was considering one and even built the shop and over poured the slab to accomodate one. Half of my fleet are the big bolts and I didn't want to work around the posts that the trucks would have to squeeze between to get into the shop. For now I've decided against it until I get too old to lay under the trucks (which I don't think will be long). Besides, I use one at work everyday. I have access to a dozen hoists every week-end and evening so I thought I would keep my floor space for now. Besides, it's hard to have a barn dance with a shop lift right in the middle of the floor. Scott | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | One of these days i'm going to build a shop out here, and the way i've been leaning is a PIT, not a lift.
Mostly because of price.. but secondly, because of ceiling height.
| | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Topic: Shop lift or not? Buddy you should never shop lift, it's against the law!  .........g | | | | | Joined: May 2005 Posts: 17 Junior Member | | Junior Member Joined: May 2005 Posts: 17 |
Smile much, laugh alot, enjoy life: it's short.
| | | | | Joined: Dec 2003 Posts: 265 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 265 | 51 KY 3100: his lives in his basement with his 32 ford on top and his 2000 Corvette underneath, two late model bikes, a 77 Suburban, and a 1999 Excursion in front of it. He says that he plans to build a car but I don't know where he is going to do it. | | | | | Joined: Sep 2001 Posts: 466 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 466 | The 10s are overwhelming, as I suspected. I plan a 12' ceiling and maybe build a deck in one corner to store a vehicle under and body part storage on top. Also a shed roof off one side (outside) for 2 vehicles along side. The finance dept. (I Love you honey) has given approvel, it's in the 3 year plan. She thinks I should put in a heated slab floor to cut down on dust(she's so smart). Hmmmm, now that I think about it she did mention something last week about her buying an old El Camino.
I gotta go guys...........
Buddy | | | | | Joined: May 2003 Posts: 328 Shop Shark | | Shop Shark Joined: May 2003 Posts: 328 | My company just built a new factory with a heated slab. We have not used the heat function yet, but everybody we spoke with that has heated floors says that they absolutely love them. The down fall to this setup is that you cannot dtill into the floor due to the tubing that is installed in the concrete. One punctured line and you floor heat is history.
Phil
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
| | | | | Joined: Sep 2001 Posts: 466 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 466 | I have heated floor in the house garage, they are great! If I do them in the shop, the lift location will be done at the same time.
Thanks for all the input Guys.......
Buddy | | | | | Joined: Dec 2003 Posts: 265 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 265 | If you go with the lift, I'd go higher than a 12' ceiling. That's what my friend has and with his 32 Ford on it which is pretty low compared to a bolt, I can't fully stand up under it and I'm only 5'8". | | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | I built a 4' X 16' pit in my garage, I love it! No more creeper under the not enough room places, and never have to struggle with underfloor stuff. My exhaust work is now a snap. A lift would be good too, but I don't have a post (or 2 or 4) to work around. My total cost for the pit was less than $1,000.00 including 2" x 6" decking to cover it when not in use. Definitely do something to get under your car easily, you will be glad you did. Don't forget to put an electric plug in the pit too, I did and now need an extension cord to get my power in there. Also a drain if there is possibility of getting liquid in there, slope the concrete away from every edge of it too. | | | | | Joined: Jun 2004 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 100 | I have a 4 post lift in my garage, and it has been worth every penny I spent on it. A 4 post is the way to go, especially if you get the caster option, that way you can move it around your shop or outside. You really need a ceiling higher than 12'... My ceiling is 13' and I still have to stoop over a bit to get under the rails. At times I have cursed it for taking up space, but I'd just roll it outside. Buy the best you can afford. Backyard Buddy is a quality unit. If that is too much, buy some thing made in the USA, because the of the quality. I don't like the foriegn-made units... poor welds...
A lift is only as good as the guy(or gal) who welded it.
Andy
A man is like an old truck... He will rust out before he wears out...
