| | | Forums66 Topics128,151 Posts1,056,994 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Here's an interesting bit of old truck mystery..
The other day, I was having a hard time getting my truck to start.. and I noticed that turning the key to the "on" position didn't make the gas gauge needle rise.
I turned the heater blower switch on, and nothing.. then I tapped the instrument gauge with my finger.. tap tap.. and the blower kicked on, and the gauges all rose!
I hit the foot start and VROOM off she went!
So now when I get in the truck, I hit the blower switch.. if the blower dosent run, then I tap the instrument gauge glass twice.. tap tap.. and the blower kicks on, then I fire it up.
My guess is I have a bad/loose contact on the back of the gauge cluster, but it sure is a cool "Fonzie" way to start the truck!
| | | | | Joined: Nov 2004 Posts: 170 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 170 | Built in security system... its a feature! | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Having been through that same problem, I would say you probably have the problem solved. Loose connection on the back of the ammeter.
Good luck, Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | Had the same thing as Joe said. Loose wire on ammeter.
Bob | | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | And a fire waiting to happen? | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Originally posted by chuckthetruck: And a fire waiting to happen? Some folks have flames painted on.. i could have the real thing!
