0 members (), 86 guests, and 1 robot.
Topics128,151
Posts1,056,999
Members48,460
Here's an interesting bit of old truck mystery..
The other day, I was having a hard time getting my truck to start.. and I noticed that turning the key to the "on" position didn't make the gas gauge needle rise.
I turned the heater blower switch on, and nothing.. then I tapped the instrument gauge with my finger.. tap tap.. and the blower kicked on, and the gauges all rose!
I hit the foot start and VROOM off she went!
So now when I get in the truck, I hit the blower switch.. if the blower dosent run, then I tap the instrument gauge glass twice.. tap tap.. and the blower kicks on, then I fire it up.
My guess is I have a bad/loose contact on the back of the gauge cluster, but it sure is a cool "Fonzie" way to start the truck!
Built in security system... its a feature!
Regards, Kevin
1940 1/2-ton (Uncle Willie\'s truck)
Thanks for the help so far fellow Bolters!
Having been through that same problem, I would say you probably have the problem solved. Loose connection on the back of the ammeter.
Good luck,
Joe
Had the same thing as Joe said. Loose wire on ammeter.
Bob
And a fire waiting to happen?
Quote
Some folks have flames painted on.. i could have the real thing!
