| | | Forums66 Topics128,128 Posts1,056,664 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 3 Junior Member | | Junior Member Joined: Jun 2005 Posts: 3 | I have a 69' one ton with a 250 6 in it. I need to swap engines as this one is going south on me (knocking and using oil bad). My question is will my bell housing for the four speed that I currently have bolt up to a small block 283 that I want to put in it? Also, will the motor mounts need to be V8 motor mounts? Thanks for any advice in this swap. (I am still new at fixing these trucks up. I also have a 1966 C10 that I will begin working on this fall.)
Owen Miller
| | | | | Joined: Oct 2002 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 77 | Omill the bell housing and motor mounts are the same for a 250 and a small block. | | | | | Joined: Oct 2002 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 77 | Omill, all you need to do is remove the top bracket from the 250 mounts and the smal block will bolt right in. | | | | | Joined: Sep 2002 Posts: 158 knuckle head | | knuckle head Joined: Sep 2002 Posts: 158 | The V-8 will fit on the 6 mounts ok, but it'll be back a few inches ,the distributer will just clear the firewall.If you use the correct V-8 motor mount parts,the engine is foward more,but then the 6 cylinder drivetrain doesn't line up. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | You'll also need to come up with alternator mounting brackets and extend the wiring to reach to the other side of the engine, nothing hard about this swap though, Scott | | | | | Joined: Jun 2005 Posts: 3 Junior Member | | Junior Member Joined: Jun 2005 Posts: 3 | Thanks for the advice, guys. I appreciate it. I just wanted to cover all the basics before the actual swap and find something not working.
Owen
Owen Miller
