0 members (), 120 guests, and 3 robots.
Topics128,093
Posts1,056,474
Members48,444
#184470 06/28/2005 4:51 PM
Junior Member
Junior Member
I have a 69' one ton with a 250 6 in it. I need to swap engines as this one is going south on me (knocking and using oil bad). My question is will my bell housing for the four speed that I currently have bolt up to a small block 283 that I want to put in it? Also, will the motor mounts need to be V8 motor mounts? Thanks for any advice in this swap. (I am still new at fixing these trucks up. I also have a 1966 C10 that I will begin working on this fall.)
Owen Miller
#184471 06/28/2005 4:57 PM
Omill the bell housing and motor mounts are the same for a 250 and a small block.
#184472 06/28/2005 4:59 PM
Omill, all you need to do is remove the top bracket from the 250 mounts and the smal block will bolt right in.
#184473 06/29/2005 1:19 AM
knuckle head
knuckle head
The V-8 will fit on the 6 mounts ok, but it'll be back a few inches ,the distributer will just clear the firewall.If you use the correct V-8 motor mount parts,the engine is foward more,but then the 6 cylinder drivetrain doesn't line up.
#184474 06/29/2005 3:24 AM
You'll also need to come up with alternator mounting brackets and extend the wiring to reach to the other side of the engine, nothing hard about this swap though,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#184475 06/29/2005 4:53 AM
Junior Member
Junior Member
Thanks for the advice, guys. I appreciate it. I just wanted to cover all the basics before the actual swap and find something not working.
Owen
Owen Miller
