8 members (55shaker, MickeyP, Bill Hanlon, 3B, Gdads51, Ridgeback, Gray_Ghost, 32Fordpuchoptop), 112 guests, and 1 robot.
Topics128,118
Posts1,056,304
Members48,439
I've got to bend up some fuel line from the pump to the carb on a '51 1/2T. Does this need to be a single flare or double? Will be using steel tube if that makes a difference.
PRW
Always do a double flare.It will have a superior seal in the fitting and will last much longer.It will also help prevent leaks which are not good to have especially in a fuel system on a hot engine eek
