| | | Forums66 Topics128,089 Posts1,056,144 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#18417 12/26/2002 9:36 PM | Joined: Jun 2001 Posts: 169 'Bolter | | 'Bolter Joined: Jun 2001 Posts: 169 | I've got to bend up some fuel line from the pump to the carb on a '51 1/2T. Does this need to be a single flare or double? Will be using steel tube if that makes a difference.
PRW | | |
#18418 12/26/2002 10:01 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Always do a double flare.It will have a superior seal in the fitting and will last much longer.It will also help prevent leaks which are not good to have especially in a fuel system on a hot engine
