6 members (cmayna, Gdads51, 3B, moparguy, MickeyP, JW51), 110 guests, and 3 robots.
Topics128,064
Posts1,055,861
Members48,428
#183372 06/08/2005 4:15 AM
She's clatterin'. Is this one new enough for the hydraulics? I haven't had it apart yet....the builder says it's out of a 3/4 ton pick up. Engine no. FO105TF
#183373 06/08/2005 1:30 PM
It has hydraulic lifters, and it sounds like you might have to adjust the valve lash.
#183374 06/08/2005 6:11 PM
Yup, I figured they needed adjustment, just wanted to use the right procedure. Thanks!
#183375 06/11/2005 1:48 PM
V
V Offline
yep they are hydraulic and just for future reference the lifters are the same as small block V8s in case you need to replace some of them
#183376 06/11/2005 9:23 PM
Hmm. I just happen to have some of those, brand new, laying around. Anyway, I adjusted them, they sound a whole lot better, but now I can hear the piston slap on deceleration.
