| | | Forums66 Topics128,024 Posts1,055,393 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 3 Junior Member | | Junior Member Joined: Jun 2005 Posts: 3 | I got an old chevy i believe that could be an awsome truck but it hasn't been run in 10 years do you think it would be worth fixing. | | | | | Joined: Oct 2004 Posts: 39 Member | | Member Joined: Oct 2004 Posts: 39 | Is it worth it to you? I keep my truck going because it's my hobby. I have probably spent more on my truck than it is worth to most people however my truck is part of the family. If you aren’t fixing up your truck for your self, or if you are looking for an investment than you may end up putting more money into a truck than you would like. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It depends on how much you can & wan,t to do yourself. If you start taking to places to have the work done it could turn into a nightmare. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2005 Posts: 313 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 313 | I had a '66 C-30 with a 250 that sat for 4+ years, and I had it running in about 20 minutes.  However, you will probably will have to go over the entire fuel system before getting your '64 running. Good luck. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | a 64 Chevy? no Bill | | | | | Joined: Apr 2004 Posts: 158 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 158 | There's two ways of determining the value of something.
From economics: What a willing buyer will pay a willing seller.
From experience: What it would cost you to replace it with something of comparable worth to YOU.
Note that the second definition is much more subjective -- the worth to you can be influenced by what your needs are, how you think it looks, how you think YOU look in it, whether it has sentimental value, etc.
By the first definition, I don't think it will be worth it. The replacement parts and your time will not make the truck more valuable than the cost of the parts and your time.
By the second definition -- the only one who knows is you. Do you LIKE the truck? Do you like working on old trucks? What are you going to do with the truck? As far as trucks go, it's a very rugged and bulletproof design. But it IS still 41 years old! You should expect to have to perform a LOT of overlooked maintenance. With my 60, for instance, I'm basically assuming that everything has to be touched. I'm planning on having a like-new truck.
Have fun!
Brian | | | | | Joined: Jun 2005 Posts: 3 Junior Member | | Junior Member Joined: Jun 2005 Posts: 3 | the real problem is money!!! I dont even have a drivers licenses yet so i dont make alot of money the most i could spend would be 500 dollars | | | | | | Anonymous Unregistered | | Anonymous Unregistered | I've got a 64 Chevy, its my daily driver. No one in the highschool parking lot (or in town for that matter) has a truck just like mine. I love it! I have worked for it and paid for it all so far on all my trucks. I have learned so much, and that makes it worth it for me. Are you mechanically inclined? Can you do much of the work yourself? Trust me, after I brought my truck away to pass a saftey inspection and get a tune up, I decided to do all the work I could by myself with the help of this great forum. Good Luck, you have to be the one that decides eventually. | | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | you have to have a love for the truck and the body style. the rest will come in time. a little work here and there. a old truck is a project of feelings, don't rush the project and you will not be disappointed in the out come. once you get in a rush it will cost to much. like i say its a labor of love, and pride in what you have accomblished..good luck..mike j | | | | | Joined: May 2005 Posts: 33 Member | | Member Joined: May 2005 Posts: 33 | Don't let anybody scare you away from it. Where has it been sitting? Sitting in a field, garage, or driveway? If the truck is complete, you are looking at mostly labor. You can fix almost everything yourself on old Chevy's. Pull the plugs & soak the cylinders. Go back tomorrow & see if engine will turn over. If yes, it's worth it. Someone you know would be glad to help. Just ask. Good luck. Scott
Life is good. Keep on playing.
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | How much money do you have available? Do you have a place to perform the needed work? Do you have the tools that will be necessary? Do you have the paitence it will require? Do you have good neighbors? Do you have any mechanical experience?
If the answer to more than two of these question is NO then you will probably be better off buying something that already runs and is safe. Leave the old truck project until a later time when you have some extra time and money. There will always be time later. Focus on school now and the other items will fall into place. | | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | you should have someone that knows cars look at it.if its not rusted too badly it might be worth fixing.btw i LIKE my 64 chevy.[eventhough id swap it for a 55-57 or 67-68].whereis mazon? | | |
