7 members (sron48, BC59, MikeStone1953, Otto Skorzeny, Hawkman, fonz8261, 1 invisible),
157
Mod | | | Forums66 Topics128,086 Posts1,056,099 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | | Anonymous Unregistered | | Anonymous Unregistered | | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 |
| | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | a 727 would be at least 20 foot wide. | | | | | Joined: Aug 2004 Posts: 476 Moderator | | Moderator Joined: Aug 2004 Posts: 476 | I saw one many years ago in a magazine article. Down in Australia, I think. The guy had put a C47 fuselage on a truck chassis and made a camper out of it.
Don't lose your head to save a minute, You need your head, your brains are in it. Burma-Shave (1947)
| | | | | Joined: Oct 2004 Posts: 39 Member | | Member Joined: Oct 2004 Posts: 39 | No good, it doesn't have a chevy motor. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | It does seem a tad narrow for a 727 and on the side view the window positions seem higher than normal. Maybe I am being thrown off by the paint scheme. | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | They probably had to chop out a section down the center and weld it back together to get it narrow enough for road use.
| | | | | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | I am shocked that there aren't any bidders yet, just shocked!
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | The window size and orientation of the cockpit windows are the same as a 727. A 727 isn't all that wide to begin with, so it may well be a standard 727 fuselage. http://www.airliners.net/info/stats.main?id=90 shows the pallet capacity. Judging from that, and the fact the 727 shared the 707 fuselage cross-section, the overall width would be a road-legal 10-1/2'.
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass. Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
| | | | | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | I moved a 727 to a lake in Benoit, Ms and turned it into a cabin..It was only about 12' wide, but 133' long..Looks like they cut it off before the back door..The owner, Joann Ussery was a close friend, and without a good grinder with bunch of cutoff wheels we would have never done it..She was on all the talk shows about 6-7yrs ago | | |
