6 members (Robert Crandall, Hotrod Lincoln, 3800GUY, JW51, Wally / Montana, 1 invisible), 78 guests, and 2 robots.
Topics128,082
Posts1,055,961
Members48,430
#183309 06/06/2005 7:06 PM
Anonymous
Unregistered
Anonymous
Unregistered
Another imaginative set of wheels from the folks at Ebay
http://cgi.ebay.com/ebaymotors/ws/e...9&category=50056&sspagename=WDVW
#183310 06/06/2005 7:35 PM
thats cool.
#183311 06/07/2005 2:48 AM
Z
Z Offline
a 727 would be at least 20 foot wide.
#183312 06/07/2005 3:17 AM
Moderator
Moderator
I saw one many years ago in a magazine article. Down in Australia, I think. The guy had put a C47 fuselage on a truck chassis and made a camper out of it.
Don't lose your head to save a minute,
You need your head, your brains are in it.
Burma-Shave (1947)
#183313 06/07/2005 1:08 PM
No good, it doesn't have a chevy motor.
#183314 06/07/2005 9:05 PM
It does seem a tad narrow for a 727 and on the side view the window positions seem higher than normal. Maybe I am being thrown off by the paint scheme.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#183315 06/07/2005 11:40 PM
They probably had to chop out a section down the center and weld it back together to get it narrow enough for road use.
#183316 06/08/2005 5:44 PM
I am shocked that there aren't any bidders yet, just shocked!
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
#183317 06/08/2005 6:16 PM
The window size and orientation of the cockpit windows are the same as a 727. A 727 isn't all that wide to begin with, so it may well be a standard 727 fuselage.
http://www.airliners.net/info/stats.main?id=90 shows the pallet capacity. Judging from that, and the fact the 727 shared the 707 fuselage cross-section, the overall width would be a road-legal 10-1/2'.
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass.
Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
#183318 06/08/2005 7:24 PM
I moved a 727 to a lake in Benoit, Ms and turned it into a cabin..It was only about 12' wide, but 133' long..Looks like they cut it off before the back door..The owner, Joann Ussery was a close friend, and without a good grinder with bunch of cutoff wheels we would have never done it..She was on all the talk shows about 6-7yrs ago
