1 members (SandraD),
56
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 314 Shop Shark | | Shop Shark Joined: May 2005 Posts: 314 | My son and I are starting our 57 panel Project. We bought a 77 K5 Blazer for the frame and drive line. (Yeah its a 350... and I know you don't all approve) I don't have a problem lengthening the wheel base 7-1/2" but the front tread width is about 6" wider on the K5. (The rear should be fine.)
I noticed that the rims on the K5 are very deep... (I don't know how to explain it) the mounting surface is such that the tires are off center to the outside.
Are there any stock rims readily available to change the offset and narrow the tread width?
Also, will it look strange with different rims on the front than the rear? | | |
