6 members (Jon G, klhansen, dt235sd, Tim Canfield, Oswald, 1 invisible), 92 guests, and 2 robots.
Topics128,035
Posts1,055,445
Members48,422
#183168 06/05/2005 12:13 PM
Junior Member
Junior Member
Hi all. Both window and door handle on each door has a pin drilled into it holding it to the shaft(in addition to the set screw). The shafts have a "groove" not a hole to recieve the pin, I discovered this when I destroyed one of the handles 'cause I could not removw the dam pin! Is the pin a "custom" fix? Any great ideas on removal.
Thanks in advance.
#183169 06/05/2005 2:12 PM
I think it is a 'custom' fix. I had the same thing on one of my window handles. I removed the set screw and the handle would not come of. Using a bit of leverage the handle popped off breaking the splined shaft on the regulator. There was a nail being used as a pin. My other handles (both trucks) have a pointed set screw, the point goes into the groove in the splined shaft. I also believe that there is another chrome screw which goes in the hole on top of the set screw to either lock it in place or add a finishing touch. I have only seen one like that but am told they are supposed to be there.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
