3 members (DougH6100, Hotrod Lincoln, fonz8261), 179 guests, and 3 robots.
Topics128,128
Posts1,056,660
Members48,450
I have a complete '54 Chevrolet five window body, in relatively good condition. I have the opportunity to get a '91 Z71 4-wheel drive frame, with all the 4-wheel drive guts. Would like to have a good 4-wheel drive in this nice looking body. Anyone have any thoughts on the wisdom (or stupidity) of attempting this marriage? Any known serious impediments? All assistance much appreciated. wjb
I'm pretty sure the track width will make your tires stick out past your fenders. May look alittle odd.
Just a thought,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Scott---Thanks for pointing that out. I'll definitely measure to see if I can determine if that will be a problem.
I was also wondering if the running board brackets would fit properly with the newer frame? wjb
Although I've never done it, there's been a lot of talk about the "S10" series truck frames and axle assemblies make a better upgrade. I know you can still put the V-8 stuff in it but have the narrower suspension. As far as the runningboards go, that would be a relatively easy modification compared to the rest of the conversion.
Take a lot of measurements which ever way you go,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
