3 members (moparguy, texas46, Gray_Ghost), 191 guests, and 3 robots.
Topics128,108
Posts1,056,236
Members48,437
#182154 02/04/2005 3:12 PM
I took my 51 hood which had top rust covered with 3 layers of paint and 1 being rolled on latex , to a place in Arlington Texas called Metal rehab.
It turned out real nice , needs very little glaze and will be fine.It was pretty interesting , they had these huge vats that they can leave a whole car in for several days to remove the paint and bondo etc... ,then they put it in another to kill all the rust and it does not harm the metal, the process takes around two weeks, pretty cool. They have a website if you are interested www.metalrehab.com .
#182155 02/04/2005 7:00 PM
Metal dipping is the only way to go. The one thing that scares me though is that after they phosphate they rinse with water. Now this can be a problem later down the road if the shop dosn't have a proper drying room as moisture can hide out between metal laps. I had everything but my cab dipped on my 46.This was sripped down by hand to bare metal and then metal treated wich had to be rinsed with water. Next time to save time I will do the cab also
#182156 02/04/2005 11:31 PM
I'm taking my cab, hood, doors and front fenders to Jackson Miss to have them dipped at Jackson metals prep. Shuld be nice when we get them, back.
Jake
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
#182157 02/05/2005 1:10 AM
Moderator
Moderator
So what does this cost?
Don't lose your head to save a minute,
You need your head, your brains are in it.
Burma-Shave (1947)
#182158 02/05/2005 2:05 AM
When we were kids, we'd say someone's car looked like it was painted with a broom, but a roller??? With latex??? Wow!
#182159 02/05/2005 1:46 PM
Brad, I have my stuff stripped at Redi Strip in Allentown, PA. A cab will run about $500 and each seperate piece is $95... Door—$95, hood—$95, fenders—$95... $1000 should about cover the cab, and another $400 for the bed. Worth every penny.
When I was dropping off an old Porsche, they had just rinsed off a "66 Mustang... Like a fresh stamping... except for the rust holes...
http://share.shutterfly.com/osi.jsp?i=EeAM27Js2csmzjQ
Andy
A man is like an old truck... He will rust out before he wears out...
#182160 02/05/2005 9:28 PM
Moderator
Moderator
Do they do any final coating? If I don't find a place close to home to get this done I would hate to spend the money for this and then have to trailer it home several hundred miles before priming it. I think I would prefer to find a body shop nearby to get it primered, and then trailer it home.
What do you think?
Burma-Shave (1947)
#182161 02/06/2005 4:05 AM
Junior Member
Junior Member
What chemicals do they use to do this??? Seems to me that any chemicals capable of taking rust off would also eat through the metal...
Id be interested in knowing the cost as well Truckrodder....It might just be worth a trip from West Texas!
#182162 02/06/2005 4:27 AM
newb - the process and chemicals to strip rust work on the rust only [oxide], not on the good metal - it's an electrolytic 'chelation' process - and the chemicals used are mainly aimed at the paint and bondo - to do a similar thing yerself at home [for small parts] check this from the techtips section here
#182163 02/06/2005 5:01 AM
When I take a body to Redi strip, they bake it at 600 degrees for about 8 hours, depending on condition. Paint, bondo, seam sealer, undercoating will all turn to ash. The dipping process removes the rust, not the paint... When I trailered the porsche body home last spring, it rained like an SOB... I wiped down the body with dilute phosphoric acid(JASCO) to remove the "flash" rust, and then heated the seams with a heat gun to remove the moisture. I've never had a problem with blistering or "acid" leaching out from the seams to ruin a paint job.
Andy
#182164 02/08/2005 2:00 PM
My hood cost around $225.00 dipped then coated with DP90 . Without DP90 I believe it was $135.00 and it has a coating on it that will get you home.As long as it is inside it will be fine when you store it at home.They said that you just wash the coating off and prime.
#182165 02/09/2005 1:22 PM
Oh I forgot to mention, I was curious how much my 72 burb would cost ,it would be $2500.00 , which does not seem too bad as big as it is and as many nook and crannys it has. I believe a truck cab cost around $300.00-$500.00. I think it is better on the parts than blasting , no worries about warping etc... .
#182166 02/09/2005 1:52 PM
I try to look at a project's "hassle-to-benefit-ratio." Yeah, I'll save money by media blasting it myself, but it is a miserable job and you end up with lead-based paint dust floating around the yard. Besides, blasting only removes paint, rust and, with a bit of effort, bondo. And only in the area you can reach. Seam sealer and undercoating will require a different, yet equally miserable job. Dipping is the best way to go...
#182167 02/09/2005 6:18 PM
ModelMan, where is Jackson metal prep? I live in So Alabama, and would like to get some of my parts dipped also. Any contact info you have would be appreciated......
Mike from Alabama
My truck on Stovebolt
My website
Why do we drive on a parkway, and park on a driveway?
#182168 02/09/2005 10:13 PM
Here is their name, address and phone #
Metal Finishing Services, Inc.
750 Boling St, Ste. C
Jackson, MS. 39209
601-355-3317
Jake
