3 members (Otto Skorzeny, Stovebolt48, Wally / Montana), 146 guests, and 3 robots.
Topics128,196
Posts1,057,382
Members48,471
So, I go home this weekend, and mom and dad say "get your truck running well, because we're moving." Apparently they bought a house about 5 miles out of town that's sitting on 18 acres of wooded land. 8 of those acres are pine trees from a defunct Christmas tree farm, and 10 acres is all hardwood - mostly oak. The pine trees really need to be cleared out as there is a lot of windfall and dead trees in there, and the oaks could use cleaned out too. so, on top of moving all our stuff out there, it's going to be hauling hundreds of pounds of wood around, pulling logs, moving brick and mortar (there was an outbuilding that fell and now it's blocking one of the tree farm paths) and pulling a trailer with a decent-sized lawn tractor on it. Also, dad wants to get an old tractor (like a Ford 8N or something), so truck truck is gonna have to move that out there as well.
I just hope the clutch is OK...This weekend when I was working on it, I figured out the charging system problem (someone hooked up 2 of the alt wires backward and it was discharging the battery) and to test it out, I took it down the road and got it up to 75 MPH before I slowed it down and went home eek eek
I am not bound to please thee with my answers. - William Shakespeare
1967 C10
1983 Olds Delta 88
sounds like fun, just don't over load it and enjoy the new place..regards..Fred
Redryder pix
My Hotrod
Socket Breaker
Socket Breaker
better stock up on the powdered gatorade so u can make yer own. smile
yeah it tastes icky, but it works when yer sweatin' like a pig.
-W
if it sees more than 700 lbs in one trip on that bed, I'll surprise myself. I am NOT going to risk having that bed wood give way at 45 mph under the weight of very valuable antique furniture.
1967 C10
1983 Olds Delta 88
Back when I got Shelley, the rotted bed had holes the size of pumpkins. Threw in a sheet of 3/8 plywood and hauled tons-0-stuff...firewood, dorm furniture, everything.
Have fun haulin'. I kinda miss putting a big ole load in the back and using 'er the way she was meant to be used.
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
Scott's right throw an old sheet of plywood or some tin in the bed--it'll haul fine.
My parent's are gettn old--every spring my brothers and I go up and haul the tree debris off--it's a chore but gotta be done. wink
Buzz'n Half Dozen
She's already got a 3/4" piece of plywood in the bed over the wood. I"m just hoping the whole mess holds together. It's already being employed as storage for some of the stuff while we get our house ready to show to the realators, with 3 very large dressers in the back. You should have seen how the rearend squatted under that weight with those tired springs. I'll make sure to post pics of the truck while it's moving stuff, as well as it's new home and surrounding property. Hey, if you're lucky, you might get to see it kicking up some sand out in the pine trees! ha.
1967 C10
1983 Olds Delta 88
Don't forget the deer rifle when you head out.
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
it's already out there grin
1967 C10
1983 Olds Delta 88
