9 members (Bizaircon, Youngin' Tut 59, klhansen, J Lucas, Hotrod Lincoln, 5 Window 9434, lumbersawyer, DougH6100, 1 invisible), 78 guests, and 2 robots.
Topics128,139
Posts1,056,762
Members48,454
ive got a line out for a 51 gmc.i know the engines,grill,and electricall wont work but am wondering if fenders doors,bellhouseing and exspeccialy tranny will be a bolt on to a 51 chevy. Thanks.Ron
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are...
My progress pics
k10 Offline
Tranny is the same. SM420. Should bolt right up.
The fenders will work, the only difference is GMC has the parking lights in the fender. The hood is different, the bumper is the same but the valence is different. The front crossmember is different. The doors, cab, running boards, most of the interior are the same. Outside of the few body panels and the engine, there are few differences. There may be some others that i did not mention but I am sure the GMC guys will let us know! grin
Yep--
Jimmies make good parts vehicles for Chebbies. Stay away from those drab grills tho. grin cool grin
Buzz'n Half Dozen
These guys are steering you wrong. The Chevy makes the best parts truck. Save the GMC.
GMC used cadmium plated bolts back then
Save the GMC`s grin
3 GMCs, 2 Chebbies. The Chebbies are both parts rigs for 2 of the GMCs. grin
Buy a REAL truck - Buy a GMC!
1954 GMC De Luxe COE
Basically, all the ugly parts won't work...
grin
54 3100 with 235
62 flatbed dump C60 with 261
i called to late and it was sold,but was told to call back as the aparently the guy is slow to come up with the cash.Arunning 51 5 window for 500 o.b.o..100% restorable.sounds like a definate i.r.w.i.p. it.
1942 1\2 Ton
1960 Biscayne Sedan
1965 G/10 panel van
My progress pics
After the '67 model year mechanicals are the same; only the trim differs.
*** GMC ***
Let us not forget that the GMCs had their batteries hooked up backwards! No wonder they had to borrow most of the truck design from the Chev design team !
1951 1 Ton Completed
Socket Breaker
Socket Breaker
American Classic - http://www.americanclassic.com
has this under 'literature'
LIT-48
1946-65 Interchange manual, 1/2 to 1 ton, Chevy and GMC $15.00 Each
I have one ordered if they can ever get my order in the mail... along with all my kooky brake parts... smile If I ever get it I'll let ya'll know about the 'cool' factor.
-W
