| | | Forums66 Topics128,154 Posts1,056,856 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | ive got a line out for a 51 gmc.i know the engines,grill,and electricall wont work but am wondering if fenders doors,bellhouseing and exspeccialy tranny will be a bolt on to a 51 chevy. Thanks.Ron
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | Tranny is the same. SM420. Should bolt right up. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | The fenders will work, the only difference is GMC has the parking lights in the fender. The hood is different, the bumper is the same but the valence is different. The front crossmember is different. The doors, cab, running boards, most of the interior are the same. Outside of the few body panels and the engine, there are few differences. There may be some others that i did not mention but I am sure the GMC guys will let us know!  | | | | | Joined: Mar 2001 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 384 | Yep-- Jimmies make good parts vehicles for Chebbies. Stay away from those drab grills tho.
Buzz'n Half Dozen
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | These guys are steering you wrong. The Chevy makes the best parts truck. Save the GMC. | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | GMC used cadmium plated bolts back then Save the GMC`s
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | 3 GMCs, 2 Chebbies. The Chebbies are both parts rigs for 2 of the GMCs. Buy a REAL truck - Buy a GMC! | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Basically, all the ugly parts won't work...
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | i called to late and it was sold,but was told to call back as the aparently the guy is slow to come up with the cash.Arunning 51 5 window for 500 o.b.o..100% restorable.sounds like a definate i.r.w.i.p. it.
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | | | | Joined: Mar 2001 Posts: 316 Member | | Member Joined: Mar 2001 Posts: 316 | After the '67 model year mechanicals are the same; only the trim differs.
*** GMC ***
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Let us not forget that the GMCs had their batteries hooked up backwards! No wonder they had to borrow most of the truck design from the Chev design team ! | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | American Classic - http://www.americanclassic.com has this under 'literature' LIT-48 1946-65 Interchange manual, 1/2 to 1 ton, Chevy and GMC $15.00 Each I have one ordered if they can ever get my order in the mail... along with all my kooky brake parts...  If I ever get it I'll let ya'll know about the 'cool' factor. -W | | |
