1 members (Rnl364), 104 guests, and 6 robots.
Topics128,077
Posts1,056,033
Members48,433
#181005 03/20/2005 5:35 PM
Junior Member
Junior Member
Pusher or puller. That is the question.
Any one know which is better for an electric cooling fan attached to the radiator.
I have a 53 GMC 5 window 1/2 ton with all the running gear from a 78 Blazer. The 400 small block is a great motor but Ive been having problems with keeping her from heating up when running at an Idle on a warm day. I've got a good , large 4 core rad, custom made shroud and have tried a variaty of fans.
I'm now junk'in the clutch fan and going electric.
Any info on the best way to go?
53 1/2-ton GMC 4x4
54 Chevy 1/2-ton
#181006 03/20/2005 5:53 PM
A good working clutch fan and a full shroud, set up properly (fan centered, depth-wise in the opening of the shroud and within 1/2" diameter of the opening), will out perform any electric fan, as far as cooling! If you "got to have" an electric, a puller behind the radiator is better (nothing blocking air travel through the radiator)!
Just trying to avoid the potholes on the road of life!
49 Chevy COE
55 Chevy pickup
+ way too many other project vehicles!
#181007 03/20/2005 6:42 PM
Junior Member
Junior Member
Thanks for the advice. That makes sense so a puller it will be. I've heard good and bad about both electric and clutch fans. I've heard alot about the Ford Taurus Two speed fan. I'm a little ashamed at the thought of putting ford parts on my truck though.
53 1/2-ton GMC 4x4
54 Chevy 1/2-ton
#181008 03/20/2005 11:19 PM
the price is right,no one will know the difference.as long as it gets the job.You can get a dial in thermostat switch for the fan also
dan-pa
#181009 03/20/2005 11:21 PM
Riding in the Passing Lane
Summit has a fan kit pulls 2800 CFM. Has good mounting brackets & adjustable therm. I used one on my 56 w/350. Worked real good. No way would I hang one on the radiator core with plastic rods. smile
1972 Chevy c10 Cheyenne Super
#181010 03/21/2005 12:05 AM
I don't know if you can keep that 400 cool with the best cooling system you can buy, they're prone to running hot from the factory. Then you stick one into a tighter area than they are used to and can't disapate the heat from around it. You may need to run a performance aluminum radiator and a puller fan with a low temp thermostat to keep it under control. Just one guy's opinion,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#181011 03/21/2005 8:22 AM
Definitely a puller. Placed at the TOP of the radiator (heat rises) for best cooling.
I put a 16 inch electric fan on my rad w/350 sbc; headers; mild cam; Edelbrock 4bbl carb ... ran double relays and a fusible link (NOT a circuit breaker) ... and my voltage gauge is very happy; she stays nice and cool, too.
Walker Z-Cool Radiator Install[/b]
[b]Wiring Your Fan w/Double Relays[/b]
[b]About Fusible Links
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#181012 03/21/2005 6:20 PM
The 350 runs best around 200deg.I would be safe to say 225deg.Mine has been there++.The new car therostat opens at 260deg.A old friend told me,Don't worry about the rad,ya can't soilder under water.He was a mechanic at Indy 500.in his younger days.
dan-pa
