2 members (Hotrod Lincoln, homer52), 97 guests, and 1 robot.
Topics128,126
Posts1,056,355
Members48,441
#180878 03/04/2005 5:54 AM
Junior Member
Junior Member
I am thinking that my 3/4 ton should have 17" split rims. Does this make sense? Does anyone know where I might find the same? I need a pair and have posted everywhere I know. My 3/4 ton has 8 lug rims.
Thanks for any advice/help.
#180879 03/04/2005 4:16 PM
My '48 3/4T had three 17" split ring rims and one 17" 1-piece rim on it when I bought it. It can be hard to get a tire shop to work on the split rims so a lot of folks go to a 16" 1-piece rim.
I put aftermarket 16" 1-piece rims with 235-85-16 radial tires on them. (I forget where the "R" goes.) There has been a lot of discussion here on the type of rim that will clear the tie rod ends up front. I found that 6 inch wide rims worked for me.
#180880 03/04/2005 5:39 PM
Junior Member
Junior Member
Michael,
My '51 had 17" split rims, but I too put 16" solid rims on because no tire shop would work with the split rims.
Therefore, I have a complete set of split rims available if you're interested.
Rob Thirlwell
#180881 03/04/2005 7:35 PM
Both my 48 and 51 3/4 ton trucks have 8-hole, 15" wheels. I thought that this was normal. I do have a couple of 8-hole, 16's that I use as spares, but I have never seen a 3/4 ton with 17's. I have seen the 1-tons with the 9' bed with 17's. Learned something today.
Ralph
rtlopez@shipleysystems.com
48 Chevy 3600 w/235
48 Chevy 3100 w/235:
You cant see the smoke on a dirt road.
#180882 03/05/2005 2:30 AM
The 67 C20 I had years ago came with 17 inch non splitrims,I wore them out and put 16.5s on it as I never did like them skinny tires. A local junkyard has a 68 with a set of 17 inch non split rims on it with radials. Jeff
#180883 03/05/2005 4:28 AM
hey wally/montana- where did you get your 16 rims??? do you know the backset??? would like to do the same with my 53 3/4 ton.
'53 chevy 3/4 ton
#180884 03/05/2005 4:33 PM
Here are a couple posts from a while back.
My 16" Rims.
Setback.
I bought the rims at the local Tire-Rama. The guy there said any tire shop should be able to get similar ones.
#180885 03/05/2005 11:04 PM
Quote
My 46 3/4 ton has 17" 8 lug split rims on it. We are going to be moving away from the splits and getting solid rims on it eventually.
Tempest
Tempest
"Find Your Inner Truck"
Silly Boys! - Trucks are for Girls!
1945 2-ton
1946 3/4-ton
1951 Chevy 2-Ton
Redliners Auto Club
What\'z It
Snow Cruisers
#180886 03/06/2005 1:26 AM
The drawing of the 3/4T in my '48 Restoration Guide shows 15" tires. The 17" tires are also listed but must have been options.
