1 members (baldeagle),
158
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 26 Junior Member | | Junior Member Joined: Jan 2005 Posts: 26 | I am thinking that my 3/4 ton should have 17" split rims. Does this make sense? Does anyone know where I might find the same? I need a pair and have posted everywhere I know. My 3/4 ton has 8 lug rims.
Thanks for any advice/help. | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | My '48 3/4T had three 17" split ring rims and one 17" 1-piece rim on it when I bought it. It can be hard to get a tire shop to work on the split rims so a lot of folks go to a 16" 1-piece rim.
I put aftermarket 16" 1-piece rims with 235-85-16 radial tires on them. (I forget where the "R" goes.) There has been a lot of discussion here on the type of rim that will clear the tie rod ends up front. I found that 6 inch wide rims worked for me. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Jan 2003 Posts: 24 Junior Member | | Junior Member Joined: Jan 2003 Posts: 24 | Michael,
My '51 had 17" split rims, but I too put 16" solid rims on because no tire shop would work with the split rims.
Therefore, I have a complete set of split rims available if you're interested.
Rob Thirlwell | | | | | Joined: Jan 2004 Posts: 255 Member | | Member Joined: Jan 2004 Posts: 255 | Both my 48 and 51 3/4 ton trucks have 8-hole, 15" wheels. I thought that this was normal. I do have a couple of 8-hole, 16's that I use as spares, but I have never seen a 3/4 ton with 17's. I have seen the 1-tons with the 9' bed with 17's. Learned something today. Ralph | | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | The 67 C20 I had years ago came with 17 inch non splitrims,I wore them out and put 16.5s on it as I never did like them skinny tires. A local junkyard has a 68 with a set of 17 inch non split rims on it with radials. Jeff | | | | | Joined: Feb 2002 Posts: 75 Member | | Member Joined: Feb 2002 Posts: 75 | hey wally/montana- where did you get your 16 rims??? do you know the backset??? would like to do the same with my 53 3/4 ton.
'53 chevy 3/4 ton
| | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | Here are a couple posts from a while back. My 16" Rims. Setback. I bought the rims at the local Tire-Rama. The guy there said any tire shop should be able to get similar ones. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Jun 2003 Posts: 92 Shop Shark | | Shop Shark Joined: Jun 2003 Posts: 92 | Originally posted by michaellubitz: I am thinking that my 3/4 ton should have 17" split rims. Does this make sense? Does anyone know where I might find the same? I need a pair and have posted everywhere I know. My 3/4 ton has 8 lug rims.
Thanks for any advice/help. My 46 3/4 ton has 17" 8 lug split rims on it. We are going to be moving away from the splits and getting solid rims on it eventually. Tempest | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | The drawing of the 3/4T in my '48 Restoration Guide shows 15" tires. The 17" tires are also listed but must have been options. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
