Brrrr
place holder
6 members (Bill Hanlon, MNSmith, Otto Skorzeny, papas52, 55shaker, TexasFarmTruck), 217 guests, and 5 robots.
Topics128,271
Posts1,058,414
Members48,485
#180862 12/21/2004 11:11 PM
Apprentice
Apprentice
The spindle dust caps are too long on my 53 Chevy for Smoothie hub caps.
Any ideas on a good fix or workable replacement.
Thanks, Kelly
#180863 12/21/2004 11:32 PM
do you have a halfton?,,,welcome to the bolt,regards,,Fred
Redryder pix
My Hotrod
#180864 12/21/2004 11:38 PM
Run down to the nearest hardware store and pick up a dust-cap-adjuster. It should be in the hammer section. I think the 5-lb model should be perfect.
Vigorously apply the heavy end of the adjuster to the cap. Test for fit, and repeat as required.
Oh, and welcome to the Stovebolt! With luck someone else will happen along with an answer you like better than mine...
#180865 12/21/2004 11:44 PM
Apprentice
Apprentice
Yes my truck's a rusty red 5 window 3100.
The Smoothie hub caps go on ok if the dust cap is off.
Kelly
#180866 12/22/2004 12:14 AM
Maybe you could pull one off and take it shopping. The local Schucks has dust caps hanging on a display, and that would allow you to compare the size.
Unless your dust caps are unusually tall, I'm not sure that you'll find many options. However, GM used the same diameter on lots of vechles over the years, so perhaps you can identify one with real short caps?
#180867 12/22/2004 2:00 AM
Are they too long because the spindle requires them to be that size? You could fabricate your own with exhaust pipe tubing and weld a plate/cap on the end.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#180868 12/22/2004 7:04 AM
"MONGO"
"MONGO"
I agree with OldSub pull one off and go down to your FLAPS and compare some and see if you can find a smaller one. I know I've seen some rubber ones for trailers maybe if those would fit then they would squash enough to get your caps on.
MONGO
Mongo's Garage
Vintage GM Truck's & Parts
https://mongosgarage.com
