Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 58 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#180280 10/23/2004 11:36 PM
Anonymous
Unregistered
Anonymous
Unregistered
sometime back something was mentioned about how much the pickups and panels weighed and i wrote that my one ton long panel weighed 6800lbs because the gvw was 8800lbsand (8800-2000(1 ton)=6800 lbs. well,I WAS WRONG, i drove my 1 ton long panel down to the feed store and put her on the scales and she weighed in a nice 4650 lbs and that was with 8 gals of fuel and full oil and nothing in the back. so why is the gvw 8800lbs?
tony'n weatherford eek grin
#180281 10/24/2004 2:19 AM
were you in the truck or out of it,,,
Redryder pix
My Hotrod
#180282 10/24/2004 2:25 AM
Because it can carry more than you thought grin
#180283 10/24/2004 2:37 AM
Because GVW stands for Gross Vehicle Weight. That would mean the vehicle and the load it is carrying for a manufacturers recommended GVW.
So according to the manufacturer, your rig should not weigh over the GVW when it is loaded.
Could void the warranty, you know.
