| | | Forums66 Topics128,043 Posts1,055,610 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 12 Junior Member | | Junior Member Joined: Jan 2005 Posts: 12 | hi, ive got a 1955 chevy pickup. i am looking to replace the rear axle. i was wondering if anyone knew of a year that chevrolet made an axle that is the same width as the one currently in my pickup. thanks for any answers. sorry for not specifying, the truck in question is a second series pickup. do any of these vehicles have posi-trac? what size is the replacement rear end? thanks again | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | if it is a 55 first series a nova has worked well for me. be sure and check the gear ratio. 3.11 or higher. the 55 first looked like the 47 thru 54 the 55 second looked totaly different. hope this helps. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Jan 2004 Posts: 288 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 288 | Well it is funny you post this. I have a 55 first series. [img] http://img.photobucket.com/albums/v374/55chevy/55Camp2.jpg[/img] I just picked up a 1977 camaro z-28 rear end. It runs 5 lugs and has drum brakes. Has a 3:42 gear ratio and will mount nicely. I plan on converting to 5 lug disc brakes up front later. This rear end only has 67,000 miles and came off a running and driving car. If you want to go with a six lug look try the 73-87 K-5 blazer. Hope this helps, Chris
Chris 1955FirstSeries
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | 60-67 6 lug 1/2 ton truck rearends fit if you re-do the spring perches. A 3.07 ratio is available.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I have been told that the small Blazer rear will fit right in,or an S10 rear should also be close.Make sure you get the gear ratio you need.If you are running an overdrive tranny a 3.73 would be nice if you are runnig a regular 3 or 4 sp.,or a 350 or 400 Turbo./then you would probably want a 3.07 or close.In your 55 you should have 3.90 gears if they are stock.I am thinking about updating my 55 2nd to a later model rear.I am running a 350 engine and 700R4 tranny,so I will be looking for 3.73 or possibly 4.11 gears.Either one will be good highway gears with that set up. | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | on the rearends.A 700r4 with 4;11 rearend are not for cruisin the highways for gas milage.For the strip' yes
dan-pa
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | The 700R4 and 4:11 gears are just fine for cruisin.It is an overdrive transmission.I am running 3:90s now and it cruises just fine.My last newer Chevy PU had the OD tranny and 4:10- gears,it worked out good. | | |
