7 members (Peggy M, Hambone, 68ironhead, 2-Ton, TUTS 59, DaveV, msmall),
54
Mod | | | Forums66 Topics128,009 Posts1,055,296 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#17984 12/13/2001 3:42 AM | Joined: Jul 2001 Posts: 32 Member | | Member Joined: Jul 2001 Posts: 32 | Onmy t-5 it is an electronic speedometer. What should i do to use the stock speedometer. or is it going to be a lot of money to convert it. thanks mike | | |
#17985 12/13/2001 4:26 AM | Joined: Oct 2001 Posts: 198 Member | | Member Joined: Oct 2001 Posts: 198 | go with aftermarket gauges, and the speedo's will use either. | | |
#17986 12/13/2001 6:01 AM | Joined: Nov 2000 Posts: 45 Member | | Member Joined: Nov 2000 Posts: 45 | According to a posting on the Inliners site, Abbott Electronics makes a gadget called Cable X that is fully programmable for using the electric tranny with the mechanical speedo. About $300.
Talk to a good GM shop, they just might have something made up for just such a change over. Who knows??? | | |
#17987 12/13/2001 12:14 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | 86 GMC fleet trucks (for a certain company) had 292 originally.They were retro-fitted with a 4.3 GM V-6 .The 4.3 was TB injected and had a computer.They had an adapter(inline)on the speedo cable for the computer to have a signal for proper operation of the updated system. In your case, you have the sensor at the tranny where the old speedo gear was plugged in on the 85 and earlier trannys.You might try to find anearlier type tranny.It will be cheaper than going with an electronic speedo.
