4 members (Guitplayer, Hotrod Lincoln, Bill Hanlon, Gdads51), 106 guests, and 2 robots.
Topics128,109
Posts1,056,271
Members48,439
#179509 04/14/2005 12:57 AM
Been lurking on this forum for quite some time. In college so I don't have money for the stovebolt however I do have a honda (I know...), which is where my question lies. She is starting to develop some rust and I don't care for it too much. Knowing that some of you guys have used POR-15 for restoration work I was curious if it could be used for my honda's rust problems? I was thinking of applying it to the rusted areas, front and back and then painting it with a rattle can to make it look nice. Would this work? Is there an easier way? Any help would be greatly appreciated. Thanks.
Clark
#179510 04/14/2005 2:24 AM
Welcome
Yep, it should work. Paint both sides then topcoat it.
Good luck.
Gravity - It's not just a good idea, it's the law.
#179511 04/14/2005 3:45 AM
Anonymous
Unregistered
Anonymous
Unregistered
I have heard of Por-15 all over the place but never really looked into it. I hear it is good stuff though. Could someone please tell me more about it and give some expirences you have had with it?
#179512 04/14/2005 9:18 AM
That kind of application is exactly what POR-15 is meant for.
Paint & Body Shop moderator
#179513 04/14/2005 6:03 PM
Thanks for the replies Bill and 4. I'll give it a try and hopefully from then on my car won't be falling apart around me while driving.
Clark
#179514 04/14/2005 6:53 PM
Make sure the surface is sqeeking clean from grease - use metal /prep/clean or break cleaner.
Even greasy finger prints can make por 15 peel off.
But if you prep the surface right it is the best paint money can buy.
Frank
p.s. POR means paint over rust - it works not so good on blank metal.
#179515 04/15/2005 3:42 AM
Anonymous
Unregistered
Anonymous
Unregistered
So you can paint it right on top of rust?
#179516 04/15/2005 7:13 AM
That`s what POR is is made for. Just remove the loose stuff with a wire brush and than degrease everything.
#179517 04/16/2005 1:37 AM
Apprentice
Apprentice
Be sure to where gloves when using this because it will not come off of your hands for 7 days. I learned the hard way. The fumes are very toxic use in a well ventalted area. The stuff really works good. I used it on my floor pans as well in the whole engine compartment
