7 members (3B, Bill Hanlon, TooMany2count, Otto Skorzeny, Peggy M, GDW, 1 invisible),
114
Mod | | | Forums66 Topics128,139 Posts1,056,460 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 5 Junior Member | | Junior Member Joined: Apr 2005 Posts: 5 | I will like to lower my 55 1st series, by using lowering blocks in the back and the front. I have access to 1955 second series lowering blocks, will they work for my 1st series truck? | | | | | Joined: Feb 2005 Posts: 81 Member | | Member Joined: Feb 2005 Posts: 81 | putting lift bolcks on the front leaf springs is not a good idea. i'm pretty sure it's illegal in california, and it's unsafe too.
check the spring dimensions, if the blocks you have match up in width i don't see why you can't use them. it's also a good idea to get new U bolts, nuts and washers while yo're in there. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | I used some blocks from Autozone for the rear. The only good way to lower the front straight axle is to have the axle ends bent by an experienced shop. | | | | | Joined: Apr 2005 Posts: 5 Junior Member | | Junior Member Joined: Apr 2005 Posts: 5 | Thanks, I will look into bending my axle for the front, I also will check aouto zone. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Being in California, look for Mor-Drop. They may be in Oakland. They will drop your axle for you.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | Or you can get new axles already dropped at CenPen Speed Shop. A bit pricey, though.
Curt ---- 1953 Chevy 6400, 1957 Chevy 2dr Sedan --"Mediocrity is easy, the good things take time"
