2 members (Hotrod Lincoln, klhansen), 119 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
Junior Member
Junior Member
I will like to lower my 55 1st series, by using lowering blocks in the back and the front.
I have access to 1955 second series lowering blocks, will they work for my 1st series truck?
putting lift bolcks on the front leaf springs is not a good idea. i'm pretty sure it's illegal in california, and it's unsafe too.
check the spring dimensions, if the blocks you have match up in width i don't see why you can't use them. it's also a good idea to get new U bolts, nuts and washers while yo're in there.
Anonymous
Unregistered
Anonymous
Unregistered
I used some blocks from Autozone for the rear. The only good way to lower the front straight axle is to have the axle ends bent by an experienced shop.
Junior Member
Junior Member
Thanks, I will look into bending my axle for the front, I also will check aouto zone.
Being in California, look for Mor-Drop. They may be in Oakland. They will drop your axle for you.
Paint & Body Shop moderator
X
X Offline
Or you can get new axles already dropped at CenPen Speed Shop. A bit pricey, though.
Curt
1953 Chevy 6400, 1957 Chevy 2dr Sedan
--"Mediocrity is easy, the good things take time"
