2 members (delky, Steelonsteel),
235
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2002 Posts: 144 Member | | Member Joined: Dec 2002 Posts: 144 | I was wondering if anyone has purchased A Universal Gas Tank? I would like to take the tank from inside the truck and install it Under The Bed. On both the 46 and the 37.
If youve purchased one. What company did you use and are you happy with it? If anyone has any photos please send me a few to look at so I can get some ideas on how they have been installed.
Thanks in Advance for the Help Best Wishes Classic Finn | | | | | Joined: Apr 2004 Posts: 219 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 219 | Is this what you're looking for? This is for 63-66. This is available at American Classic Trucks. Jim Sgrig [img] http://www.americanclassic.com/images/GTN-K05.gif[/img] | | | | | Joined: Apr 2004 Posts: 219 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 219 | Maybe this will work. (Chevy Duty)
(1947-54) Gas Tank - Under Bed Image not available This is a new 20.5 gallon Stainless Steel Gas Tank that is located under the bed. It replaces the the factory tank that was located in the cab. It is located behind the rear axle and requires the spare tire mount to be eliminated. (*No Free Shipping) *Note: This item may be drop shipped from the manufacturer and could take 1-2 weeks for delivery. Part # 23-924A | | | | | Joined: Dec 2002 Posts: 144 Member | | Member Joined: Dec 2002 Posts: 144 | All right thank you!  What was the price of somthing like that? Ive seen the poly tanks but... I suppose there,s the pro,s and con,s on them too as which to use. Thanks again best wishes Classic Finn | | | | | Joined: Apr 2004 Posts: 219 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 219 | The tank in the photo is 205.00 plus shipping for the entire kit. The stainless steel tank is in the $600-700.00 dollar range.
Jim Sgrig | | | | | Joined: Apr 2005 Posts: 2 Junior Member | | Junior Member Joined: Apr 2005 Posts: 2 | Hello. I have found that the mustng two tank fits nice between the rails at the very back of truck and the filler can be plumbed wherever, and are readily available at salvage yards for 30 or 40 bucks and new are only a little over a hundred. Hope this is some help. L.D. | | | | | Joined: May 2001 Posts: 47 Member | | Member Joined: May 2001 Posts: 47 | Hey Finn,L.D. is right.I've heard the mustangII works good.I had thought about it for my 37 and running the neck up through one of the bed boards or rather make a little trap door to raise and refill. I've seen some that used a recessed stainless still piece with a little "lid" on it. Sort of like the kitchen sink dish drain with a lid on it...understand???? Catch you later Finn, check your email. | | | | | Joined: Dec 2002 Posts: 144 Member | | Member Joined: Dec 2002 Posts: 144 | Im going to check into this! Sounds like a great idea. Them Mustang 2 tanks are they also easily purchased there in the States.? Im definitely going to check into that.. I need one for the 46 and 37 so I guess the 37 would get the Mustang tank if I can locate one from someplace. Then the tank from American Classic Trucks for the 46.. Good idea! Thank You! Alvin get back online would you!!!  | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | They showed using a PT Cruiser gas cap door on one of the car shows on TV this last weekend. Cut a round hole in the bed wood then used a router to cust a slight recess for the outer piece. That made it fit flush with the wood. Looked pretty nice to me. They come painted or chrome.
40 Chevy 1/2 ton
| | | | | Joined: Mar 2005 Posts: 158 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 158 | LD Davis mentions the Mustang II tank being available new for just over a hundred. Is this referring to an OEM Ford part? Got a part #? Aftermarket? Which supplier? If I can't figure out the best way to mount this '71 Chevelle tank, I may be looking for alternatives.
Cheers, mark. '51 3100 IRWIPI... | | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | What's wrong with just leaving it in the cab? Putting it in the rear might be more dangerous if you get rear-ended.
delete my account and pictures
| | | | | Joined: May 2002 Posts: 155 Shop Shark | | Shop Shark Joined: May 2002 Posts: 155 | I'd leave it int the cab..as the old trucks are made of steel, not pop cans..If you look at all of the crashes that burned or exploded with the tank in the cab they were the pop can trucks not the real steel ones...
Geoff 49 Chev 4400 59 Apache 32
Geoff
68 GMC 3800 56 JD420C w/JD90 Loader
| | | | | Joined: Dec 2002 Posts: 144 Member | | Member Joined: Dec 2002 Posts: 144 | One reason is the smell and fumes inside the truck! Another is the women folk! Some are deathly afraid of A FuelTank Under their buttocks! This is one reason out of all the reasons in question! Classic Finn | | | | | Joined: Mar 2005 Posts: 158 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 158 | Me? I want the room in the cab for other stuff...
Cheers, mark. '51 3100 | | | | | Joined: Mar 2005 Posts: 16 Junior Member | | Junior Member Joined: Mar 2005 Posts: 16 | this is great info. I want to move my tank out of the cab too and maybe on my '56 1-ton flatbed behind the rear axle would work well. Any comment? thanks, Frank | | | | | Joined: Feb 2005 Posts: 8 Junior Member | | Junior Member Joined: Feb 2005 Posts: 8 | I just bought one from yogi's, its a universal poly tank for trucks, only downfall i forsee right now is that it is only 14.5 gallons. I should get it at the end of this week. Ill let yall now how it works out. Was $225 for tank, neck, straps and billet cap. | | | | | Joined: Dec 2002 Posts: 144 Member | | Member Joined: Dec 2002 Posts: 144 | Hello jkastner51
Let us know how it comes together and if you have a link to a photo of it then too so we could take a look.
14.5 gallon would be big enough for me since the gas prices are really high over here..
Classic Finn | | | | | Joined: Feb 2002 Posts: 75 Member | | Member Joined: Feb 2002 Posts: 75 | I used a 70 Mustang tank (new) for about $115 delivered. Mine's a flatbed, so didn't have to screw with fender fill door.
'53 chevy 3/4 ton
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | What kind of tank will fit nicely in the rear of a 64? I am going to leave the tank inside on my 53, but on my 64 I would like to move it. Thanks | | |
