1 members (klhansen), 70 guests, and 3 robots.
Topics128,094
Posts1,056,064
Members48,433
#177450 04/02/2005 8:44 PM
I was wondering if anyone has purchased A Universal Gas Tank? I would like to take the tank from inside the truck and install it Under The Bed. On both the 46 and the 37.
If youve purchased one. What company did you use and are you happy with it? If anyone has any photos please send me a few to look at so I can get some ideas on how they have been installed.
Thanks in Advance for the Help
Best Wishes Classic Finn
#177451 04/02/2005 9:10 PM
Is this what you're looking for? This is for 63-66. This is available at American Classic Trucks.
Jim Sgrig
[img]http://www.americanclassic.com/images/GTN-K05.gif[/img]
"I can go anywhere...for I am a Piewagoneer...To the Piewagon"
1966 Chevy Panel Delivery 1966 in the Gallery and more on Webshots
#177452 04/02/2005 9:24 PM
Maybe this will work. (Chevy Duty)
(1947-54) Gas Tank - Under Bed
Image not available This is a new 20.5 gallon Stainless Steel Gas Tank that is located under the bed. It replaces the the factory tank that was located in the cab. It is located behind the rear axle and requires the spare tire mount to be eliminated. (*No Free Shipping) *Note: This item may be drop shipped from the manufacturer and could take 1-2 weeks for delivery.
Part # 23-924A
#177453 04/02/2005 9:55 PM
All right thank you! wink What was the price of somthing like that?
Ive seen the poly tanks but... I suppose there,s the pro,s and con,s on them too as which to use.
Thanks again
best wishes Classic Finn
#177454 04/02/2005 10:51 PM
The tank in the photo is 205.00 plus shipping for the entire kit. The stainless steel tank is in the $600-700.00 dollar range.
Jim Sgrig
#177455 04/05/2005 10:47 PM
Junior Member
Junior Member
Hello.
I have found that the mustng two tank fits nice between the rails at the very back of truck and the filler can be plumbed wherever, and are readily available at salvage yards for 30 or 40 bucks and new are only a little over a hundred.
Hope this is some help.
L.D.
#177456 04/06/2005 4:19 AM
Hey Finn,L.D. is right.I've heard the mustangII works good.I had thought about it for my 37 and running the neck up through one of the bed boards or rather make a little trap door to raise and refill. I've seen some that used a recessed stainless still piece with a little "lid" on it. Sort of like the kitchen sink dish drain with a lid on it...understand???? Catch you later Finn, check your email.
#177457 04/08/2005 12:16 AM
Im going to check into this! Sounds like a great idea. Them Mustang 2 tanks are they also easily
purchased there in the States.? Im definitely going to check into that..
I need one for the 46 and 37 so I guess the 37 would get the Mustang tank if I can locate one from someplace. Then the tank from American Classic Trucks for the 46..
Good idea!
Thank You!
Alvin get back online would you!!! grin
#177458 04/08/2005 2:04 AM
They showed using a PT Cruiser gas cap door on one of the car shows on TV this last weekend. Cut a round hole in the bed wood then used a router to cust a slight recess for the outer piece. That made it fit flush with the wood. Looked pretty nice to me. They come painted or chrome.
40 Chevy 1/2 ton
#177459 04/08/2005 2:22 AM
LD Davis mentions the Mustang II tank being available new for just over a hundred. Is this referring to an OEM Ford part? Got a part #? Aftermarket? Which supplier? If I can't figure out the best way to mount this '71 Chevelle tank, I may be looking for alternatives.
Cheers,
mark.
'51 3100
IRWIPI...
#177460 04/08/2005 3:17 AM
Tab Offline
What's wrong with just leaving it in the cab? Putting it in the rear might be more dangerous if you get rear-ended.
delete my account and pictures
#177461 04/08/2005 7:54 AM
I'd leave it int the cab..as the old trucks are made of steel, not pop cans..If you look at all of the crashes that burned or exploded with the tank in the cab they were the pop can trucks not the real steel ones...
Geoff
49 Chev 4400
59 Apache 32
Geoff
68 GMC 3800
56 JD420C w/JD90 Loader
#177462 04/08/2005 11:51 PM
One reason is the smell and fumes inside the truck! Another is the women folk! Some are deathly afraid of A FuelTank Under their buttocks!
This is one reason out of all the reasons in question!
grin grin
Classic Finn
#177463 04/09/2005 2:06 PM
Me? I want the room in the cab for other stuff...
Cheers,
mark.
'51 3100
#177464 04/11/2005 4:21 PM
Junior Member
Junior Member
this is great info. I want to move my tank out of the cab too and maybe on my '56 1-ton flatbed behind the rear axle would work well. Any comment? thanks, Frank
#177465 04/12/2005 5:03 AM
Junior Member
Junior Member
I just bought one from yogi's, its a universal poly tank for trucks, only downfall i forsee right now is that it is only 14.5 gallons. I should get it at the end of this week. Ill let yall now how it works out. Was $225 for tank, neck, straps and billet cap.
#177466 04/13/2005 7:16 PM
Hello jkastner51
Let us know how it comes together and if you have a link to a photo of it then too so we could take a look.
14.5 gallon would be big enough for me since the gas prices are really high over here..
Classic Finn
#177467 04/14/2005 2:51 AM
I used a 70 Mustang tank (new) for about $115 delivered. Mine's a flatbed, so didn't have to screw with fender fill door.
'53 chevy 3/4 ton
#177468 04/14/2005 3:40 AM
Anonymous
Unregistered
Anonymous
Unregistered
What kind of tank will fit nicely in the rear of a 64? I am going to leave the tank inside on my 53, but on my 64 I would like to move it. Thanks
