| | | Forums66 Topics128,140 Posts1,056,776 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#17719 08/27/2004 10:29 PM | Joined: Aug 2003 Posts: 19 Junior Member | | Junior Member Joined: Aug 2003 Posts: 19 | This is probably one of those really simple things I'm trying to over think but if someone could explain how it's done: I've got a 50AD. I've got a F*rd rear axle out of an Exploder, the width is right and disks breaks are nice. Now how do I mount this thing on my stock rear springs so that they are centered in the wheel well. I observed that the mounts on the old axle were actually on the front of the axle, the F's are centered and that will move the wheels off of center in the well. The way to correct this is...? Thanks Sometimes I just get lost in the process and get so hung-up on something. | | |
#17720 08/27/2004 10:35 PM | Joined: Oct 2001 Posts: 194 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 194 | Some people say all you have to do is reverse the springs. This is supposed to move the center tie bolt about 2 inches to the rear which should come pretty close to centering the wheel in the fender. | | |
#17721 08/27/2004 10:51 PM | Joined: Aug 2003 Posts: 19 Junior Member | | Junior Member Joined: Aug 2003 Posts: 19 | Good Lord, could it be that simple!! Please let it be so and thanks afu for giving me hope that it could just be. | | |
#17722 08/28/2004 3:00 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I used springs from a '55 first series. The hole is exactly centered in the spring. This leads me to believe if the earlier spring were reversed, the hole would be too far aft. | | |
#17723 08/28/2004 3:35 AM | Joined: Dec 2003 Posts: 74 New Guy | | New Guy Joined: Dec 2003 Posts: 74 | Could you drill a locator hole in the right place on the Explorer spring perches? | | |
#17724 08/28/2004 5:00 AM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | If the Explorer spring perches line up, drill em for the center bolts. If not buy new spring mounts, drill those,clamp em in place ,check out everthing, weld them.The spring center bolt hole needs to be moved about two inches.I 've done this several times, very easy. | | |
#17725 08/29/2004 8:27 AM | Joined: Dec 2003 Posts: 74 New Guy | | New Guy Joined: Dec 2003 Posts: 74 | I had a related question: When swapping out the rear end do you have to take into account the taper of the leaf springs? I mean, do you have to weld the spring perches on a little crooked to account for the fact that the leaf spings are closer together at the front?
By the way, how did the Explorer rear end work out for ya?
Keahi | | |
#17726 08/30/2004 10:05 AM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | When using the original style springs, the taper is a non issue with replacement axle perches designed for 2-1/2 wide springs | | |
#17727 08/30/2004 2:11 PM | Joined: Aug 2003 Posts: 19 Junior Member | | Junior Member Joined: Aug 2003 Posts: 19 | Well, I did manage to get the springs turned around this weekend but I haven't had a chance to mount the axle as we decided to finish repairing my father-in-law's frame and start mounting the IFS before we forget how it's done. As it sits now it looks like it will work but... The width, at least on the 97 Mountaineer axle I've got, looks good. How it works out for me in the end is still a ways down the build but I'll be sure to post the end results. | | |
#17728 08/30/2004 4:24 PM | Joined: Feb 2004 Posts: 29,844 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,844 | On our open-wheel dirt trackers, we used to drill several spring center bolt holes in the axle perches, and shorten up the wheelbase an inch at a time during the racing season. No fenders made it easy, because the wheel openings wouldn't give us away. We'd start at the minimum legal length for early-season tech inspection, and get 3" shorter by the end of the season. We had to install a shorter driveshaft every time, but short wheelbase cars got around the turns better! (It ain't cheating unless ya get caught!) Jerry
#17729 08/31/2004 5:23 PM | Joined: Jan 2004 Posts: 223 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 223 | I am in the process of a frame off resto of my '50 3100. Years ago (about 25 years, I have had it for awhile) I switched to open driveline and fabbed up spring mounts. I visually centered the axle in the wheel well and drilled the mmounting hole, which was closer to 4" forward of the axle centerline. I am going to redo the rear axle mounts and move the mounting hole to closer to an inch or two forward of centerline to move the axle visually towards the front of the wheel well. I believe this is how they should look stock. Is this correct? I know that the rear suspension is designed to move axle back under load, but I believe stock appearence without load is the wheel sitting forward in wheel well. Steve O | | |
#17730 09/02/2004 1:28 AM | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | there are a number places that offer a relocating and lowering block combination. fatfendered.com has an online catalogue also rbsauto.com. hope this helps. i am in the process of installing a complete spring and lowering kit from fatfendered. i would be interested to know the exact width of the rear axel you will be using. measure from wheel mounting surface to surface. its fifficult sneakink on the lots when the salesmen aren't looking and climbing under to measure. iam currently useing a 79 nova rear but had to use spacers with the tires i have it is about 3 inches over all to narrow with 235/70/15 tires. and has a 2:73 rear to low numericaly. 3:11 would be better. somewhat better since i just put on fenton headers w/dual exhaust& offenhouser intake w/ two single rochesters. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
