8 members (Hotrod Lincoln, MickeyP, Peggy M, 55shaker, klhansen, Craig /49 Panel, Shaffer's1950, Otto Skorzeny),
69
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,132 Posts1,056,386 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 328 Member | | Member Joined: Nov 2004 Posts: 328 | So, what are you doing??
Here's my plan: Replace the door striker Oil Change Car wash and vacuum Bed cleanout Get and install weatherstripping Install A.I.R. pump (and figure out where to get the hoses) And, whatever else I can get done! | | | | | Joined: Jan 2004 Posts: 210 Member | | Member Joined: Jan 2004 Posts: 210 | It's about 2 pm eastern and I just finished painting my seat frames in the 46 burb. WHAT A PAIN! Too many corners and places to miss. It's done now though!  Jim | | | | | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | Right now I'm watching it rain cats and dogs on both my trucks for about the 5th day this week. Aargh! And it's supposed to rain thru Tuesday. And it's a 3 day weekend! :mad: Jeez Louise, I may as well be stationed in Whidbey Island, WA. All rain and no sun makes a wrench turner a dull boy. Hope the rest of y'all are having better luck. -David | | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | I am at work!  popcorn The Truth is Out There (Oh well it's all OT more parts please) | | | | | Joined: Feb 2001 Posts: 12 Junior Member | | Junior Member Joined: Feb 2001 Posts: 12 | I'm going to install a new pertronix electronic ignition system,and bleed the brake system on the new dual master cylinder install. | | | | | Joined: Jan 2005 Posts: 305 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 305 | Ihave to put a cluch in my 91 chevy so i have some thig to drive come tuesday to work i also have to put new exgust on it to pass state inspection :mad:
ya I know a few rednecks.Thay all drive chevys to, Proud member of the Old Dominion Stovebolt Society AND A MARINE trucks range from 1942 1/2 ton to 1965 fire engine
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | Sanding and primeing one box side, unseizing one valve, welding a little on my rear fenders. Hope to get all of that done and have some time for some snowmobiling!!! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | mugsy - you'd prolly be better off on Whidbey - they must be gettin the same sunny, dry spell we've had on Vanc Isl for a couple weeks now - guess you didn't hear that Calif wants us to export water - easiest way = send you the rain! I'm thinkin about the panel project that will hopefully be the full time job by spring - meanwhile I've been wandering around in the sun doing little jobs like stackin some firewood, feedin the compost, organizeing the greenhouse and garden for planting, gettin ready for SPRING!!!  the fiddlin that's needed on the drivers can wait Bill | | | | | Joined: Jan 2005 Posts: 192 Member | | Member Joined: Jan 2005 Posts: 192 | sat in the truck,(which is in the shed ) and contemplating my next move..... yup tear it apart...see ive got two rusty 59's and don't know where to start,bad back problems etc are plaguing me so all i can do is sit in it ,I've got enough pieces to do one good truck but it will have to wait. so i sit and write a list and keep the dream alive.  | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I removed the dual carb setup and rebuilt the fuel pump on my 1962........Merc 450 outboard motor.
Two carbs on the 261 in my '48 Chev would be great but I don't think these Tillotsons would do the job. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I replaced the HEI distributor in my 64 today after it wouldn't start before work yesterday. I drove it to where it was and in the morning, nothing, cranks no start. Checked spark, none. Had power all of the way to the cap. Had a spare distributor on the shelf, slid it in started right up. Glad it did this at home. Then I did some sandblasting on some small parts for the 63 I'm restomodding and treated them with rust-seal. Then I did some wiring in our basement to add some outlets. Our house is only 2 years old, but I wanted to see if the basement would stay dry before finishing it. Tomorrow I'm going to visit my gramma which lives about three hours away. Later, my wife and I will finally get to sit down and watch a movie together, haven't done that in a while. Scott | | | | | Joined: Jan 2001 Posts: 332 Big Bolt Shop Curmudgeon | | Big Bolt Shop Curmudgeon Joined: Jan 2001 Posts: 332 | Well, all I did was crank up (not literally) the '46 and drive into Georgetown to the bank and Wal-Mart. Had a nice drive.
Drivin' down a 2 lane country road in a stovebolt.....cowboy, it don't get no better than this!
1946 1-1/2 ton Chevy "Ol Blue", or "THE BIG 'UN"
| | | | | Joined: Jun 2002 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 272 | It is raining a ton so I will not be finishing my yard work. I am trying to strip the inside of a fender that is all rusty with all of the wrong tools. Frustration and the absence or negligence of proper saftey equipment leads to injury. Over spent on products to do simple body work and I also bought a filter/regulator for the compressor that is hooked up improperly for now since I lack the proper parts for now. So it it another angry unproductive weekend after an overworked frustrating week. I should have stayed at work. | | | | | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 | Fire up the kerosene heater and try and finish the the rebuild of my brakes...still left is a couple of coats of chassis black on rear driver side backing plate, bolt-up new emergency cable,and then wheel cyliner, shoes, return sping. Not sure how far I'll get....may just listen to my Sirius satilite and smoke too many cigars!!
49Lonnie..what dual master did you use? TooMany....I grew-up in Cahokia, give me a pm
Blue 50
1950 3100 w/57 235 Patrick’s Saginaw 4 speed and 3:55 rear end | | | | | Joined: Nov 1995 Posts: 5,723 24601 | | 24601 Joined: Nov 1995 Posts: 5,723 | Checked out a free, "It Ran When I Parked It" IH T-9 bulldozer (comes with a heap of additional scrap metal, um, I mean a parts bulldozer). When I looked into that dark glass, I saw the end of my marriage. Wisely left it in place. Also available was a '64 1-Ton Chevy van that had been cut down into a flatbed. Runs, some significant rust. Homemade cab modification and flatbed. "What are you wanting for it?" sez I. "Two," sez farmer. "Two...?" asks I, hesitantly ... "Thousand," sez farmer. "Well, I check around and see if I know anyone who's interested," sez I, choking my urge to guffaw. Went home and rearranged the shop, drove the JD 420 around and got the tires dirty. set fire to three burn piles John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | IN2Deep: You and I must work for the same place! Got called at 5:30 AM "Ben the sidewalks are slick". The way its going I will be in out of work all day. I may have to take Tuesday off oh well that was a short dream.
popcorn The Truth is Out There (Andre been fighting Arthuritis in both hips Dang :mad: ) | | | | | Joined: Apr 2001 Posts: 162 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 162 | Friday: Cleaed up the garage floor from the winter mess and whatnot.
Went to a tag sale of the estate of a local photographer and camera shop owner. Bought two pocket knives an old timer with his name stamped in it and a brand buck 303u.
Saturday: Swap meet. Bought stainless kickdown cable, stainless throttle cable for the truck. Traded a bumper for two side marker lights on my satellite and got some edelbrock throttle adapters the car needed. Coached 7th grade basketball game at church.
Sunday: Church. Grandmas 79th birthday party. Daytona 500.
Monday: Chucke Cheese in St. Charles which is a two hour drive. Then over to fastlane cars in St. Charles then back home. Big family day.
53 3100 1929 Ford Roadster Pickup 1934 Ford Pickup 68 Plymouth Satellite RR Clone 2 Door My Fleet
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Worked in the woodshop,it is heated.I did get my drums off the rear of my 55 and start draining it,in preparation for pulling the axles.Hopefully we will get a warm day soon to finish the job. | | | | | Joined: Jun 2002 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 272 | Part 2 The rain slowed today. I graded some of the area surrounding the house so it will drain properly but it was tooooo mushy I will dry again on a dryer day. Replaced several sprinklers and it started to rain again. I picked up the garage a bit. Continued my fender stipping struggle. I am near finished. Whe I got bored with the stipping I took the makeshift grinder to the sloppy welds of the previous owner. I also tried to fill 2 small holes in the fender with my new welder and poor welding skills. The holes are filled. I hope I will not be needing them for anything. While welding I set the trash can on fire! I know I can;t be the first to do that. The rain can be usefull in these situations. I took the can outside and turned it upside down. yard graded, sprinklers in, fender sorta stripped holed filled and the fire is out! a better day today that yesterday. | | | | | Joined: Dec 2002 Posts: 3,442 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,442 | I did pretty much what all the other SoCal bolters were doing..... dodging the rain, mucking in the mud and playing with fire (in my fireplace).
I did get some un-necessary drain pipes installed (now it's trying to turn itself into a mud flow).. and got a couple of water pipes and an electrical conduit to my yard shed buried. Then pulled the wire, and hooked it to a hot lead i found next to a power pole... I only got shocked twice... and the lights are really bright too..
darn, it's getting darker outside.. and its not even 9 am.
I tried to start The Ox, but the battery is dead.. must be time to buy a new Diehard.
