2 members (3B, baldeagle),
105
7
Mod | | | Forums66 Topics128,014 Posts1,055,328 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | I've had my 54 3100 w/235 for 4yrs...never had a cooling problem or any leaks..it's originally a down south hot weather truck..anyway, was fixin to do a cooling system flush and looked at the radiator cap...14#?..everything i see in my books says 4#..anyone have a clue why it all works well with the cap i have, and should i change to a 4#? Sure would appreciate a response, gonna be headed to the parts store for some other things...thanks | | | | | Joined: Aug 2003 Posts: 31 Junior Member | | Junior Member Joined: Aug 2003 Posts: 31 | My 53 has a presure relief valve in the upper radiator tank facing the engine. I've tried to pressurize the cooling system once with a pump up type of tool and could only get it to four pounds before it would release. I think that's typical. So the cap rating is probably not important.
I feel like I'm diagonally parked in a parallel universe.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I don't think that you want to use a 14 lb cap unless the book says so. I was under the impression that the Chev rad did not have the pressure relief valve. | | | | | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Appreciate it..cap is old anyway, so probably just replace it with a new 4#..thanks | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | shopper I would go with a 4lb cap.the raditor is getting old and thin.something like old people.
dan-pa
| | | | | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Got that right...starting to feel a little old and thin myself...Old Fred sure runs good though, had a good gone through today and some new hubcaps...looks like tomorrow is a cruising day...supposed to rain, but my vacuum wipers work good when i remember to let up on the gas | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Yup. Stay with a 4# cap, or you could wind up pushing water out of all the wrong places.
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
